19th June 2022
Posts: 8,266 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
I don't think a 650 Trumpet is worth the price f a few helicoils.
I woulda just sold it for scrap.
19th June 2022
Posts: 291 Sportster/Buell Model: xlch Sportster/Buell Year: 1972 Other Motorcycle Model: homebilt fxr Other Motorcycle Year: 80+
still ride one along w/sporty
https://ibb.co/4K4pYGG
pete
20th June 2022
It's a shame they are such a pretty little engine. If they looked more like a Royal Enfield Crusader no one would ever buy one.
They are a bit like having a 1300 cc sports car. It's all fine until you drive a Corvette.
20th June 2022
Posts: 1,915 Sportster/Buell Model: XLCH Sportster/Buell Year: 2003 Sportster/Buell Model #2: XL Sportster/Buell Year #2: 1981 Other Motorcycle Model: FXDC Other Motorcycle Year: 2013
Originally Posted by Jeff
Lots of good information here, lots of misinformation here. Fun fact: red loctite was designed to have the same viscosity of 20W-50 motor oil, so it can be used interchangeably when torquing "wet" fasteners. Some prefer the motor oil, some prefer the added (but false) peace of mind of the loctite.
It is extremely important to follow the manufacturer's recommendations when torquing any fastener. They, and only they, know if their specification is for a "wet" or a "dry" value. This is all over the map, to the point where it is foolish to say "all head bolts..." or "all rod bolts..." (and yes I know ours don't have them, just an example). Some manufacturers will state things like "unless otherwise specified..." and then never mention again wether their torque specs for a specific application are "wet" or "dry".
Many installations do, in fact, specify a stretch value for the fasteners rather than a torque value. This is actually a more accurate way to do this, discounting thread drag, washer drag, and that sort of thing. It is incorrect to say that once a fastener is torqued to its stretch value that it will not, when loosened, return to its relaxed length. In most applications, we endeavor to not exceed the elastic limit of the fastener, in which case most will return to their relaxed state when loosened and can be reused safely. Again, this is application, fastener, and material specific. The manufacturer knows - follow their recommendations.
There is no "one size fits all" or consistency to any of this. Specific applications simply vary too widely to say "you always...". The only thing "you always..." do is check the spec.
Thanks Jeff.
Sounds kinda like an Aircraft Tooling Engineer
I don't know much about these old beasts and appreciate some of the guys on here that do.
And I listen and learn.
I am an old metal butcher, and I learned a lot when I was young by keeping chuddup listening to the old guys before computers. And making mistakes
Been using loctite blue on the stuff that comes loose on my '81. Turn signals, seat mounting hardware-just body parts that don't get hot.
And I will be getting some nyloc fasteners
if I do any serious motor work now I know how to proceed.
Thanks guys
Steve
'01 Cyclone stock
'13 FXDC 96" stock
20th June 2022
Posts: 202 Sportster/Buell Model: PanAmerica Sportster/Buell Year: 2021 Sportster/Buell Model #2: XLH Sportster/Buell Year #2: 1985 Other Motorcycle Model: Triumph, BSA,more Sportys
It was an original 59 Bonneville...thats why owner wanted it done. If it a been a unit engine it woulda been junk
Support your local ABATE
The number of kicks required to start a sporty are in direct relationship to the number of people watching.
21st June 2022
Posts: 217 Sportster/Buell Model: XLCH Sportster/Buell Year: 1976 Other Motorcycle Model: Ducati 900 Super Sport Other Motorcycle Year: 1993
Heh heh, yeah, guilty as charged, Steve. And yes, I freely admit to a more than liberal use of both blue and red Loctite, and nyloc fasteners. I use them all, as appropriate, in those applications that do not specify torque values or methods of achieving those values. Like you say, turn signals, seat mounting hardware, body parts, etc. The stuff that seems to periodically just fall off. I believe HD were a bit negligent with regards to these "ancillary" applications. They could have done better. At a cost, of course, which was no doubt a consideration. As far as the "serious" stuff, however, wherein the engineers developed applicable specs, I will always respect their recommendations. Beyond the obvious technical reasons for doing so, there is, after all, this kind of "brotherhood" thing among us. I write my specs, they write theirs.
God invented whiskey so the Irish wouldn't rule the world
21st June 2022
Jeff,
Cost.
Could also say a bit of "lazy engineering"
Still love the old beast
21st June 2022
Posts: 15,568 Sportster/Buell Model: xlch Sportster/Buell Year: 1960 Sportster/Buell Model #2: 883 C Sportster/Buell Year #2: '03
i can still recall supermoderacer racer Will's signature..''blue loctite,put that sh**t on everything.''
