0 Wont Fire up!
0 Ebay ****evil knievel bike****
Last Post: gusm2
0 clutch issue
0 Warm/hot kickstart
Last Post: Mission1
0 "S" model specific Q&A
0 N65C or N65A
Last Post: lespaul6
Last Post: Hellbent_4
0 XR mutt race bike progress
0 Top end failure
Last Post: Mission1
0 Rubber mount gas tank part
0 Coil polarity
Last Post: davesz1r
0 '86 xl1100 help hooking up lights
0 old style fender skirted
0 Difference in Clutch Levers 45356-07 vs kit 44992-07
0 Ground Up Beginner Build
0 Sportster Fork Upgrade
Last Post: PetesPonies
Gold951 (69), tujbob (65), tcspannerwrench (54), rondog (51), scootsgal (49), barney27 (46)
backfire, carb, exhaust, s&s
Old 15th April 2013
stevo0331 stevo0331 is offline
Sportster/Buell Model: xlh 1200
stevo0331 is an unknown quantity at this point
Unhappy backfire spittin fire
Have 99 sportster with buell lightning heads and a s&s super e carb. Massive backfire with flames. Idles fine but as soon as I get the rpms up it starts with the backfire and major lugging like im out of gas then dies...unrideable..need help...cant afford the stealership
Old 15th April 2013
hellpatrol hellpatrol is offline
Sportster/Buell Model: xl1200
Other Motorcycle Model: 2 XS650's
Other Motorcycle Year: 70's
hellpatrol is just really nicehellpatrol is just really nicehellpatrol is just really nicehellpatrol is just really nicehellpatrol is just really nicehellpatrol is just really nicehellpatrol is just really nicehellpatrol is just really nicehellpatrol is just really nicehellpatrol is just really nicehellpatrol is just really nice
it's too rich, probably stalling from fouled plugs. pull them and will most likely be wet with gas after a stall
Old 15th April 2013
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
What have you recently done to it?
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 16th April 2013
The s&s is new. Probably should've said that in the beginning. The s&s guy said I needed to gap my plugs to .030....that didn't work...tried timing .....accelerator pump....nothing seems to work....
Old 16th April 2013
i've read that some of s&s carbs are too big for sportsters, only worked on 1450cc or more.. and i think it was the super E, try searching around
Old 16th April 2013
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
your too lean you need to up the pilot jet or your accelirater pump isnt reacting qick enough when you twist the trottle it should start to spray right away.
Old 17th April 2013
too lean? how do you figure it's backfiring and shooting flames? too much air isn't going to explode in the pipe
Old 17th April 2013
Skittles's Avatar
Skittles Skittles is offline
Sportster/Buell Model: XL 883
Skittles is a jewel in the roughSkittles is a jewel in the roughSkittles is a jewel in the roughSkittles is a jewel in the roughSkittles is a jewel in the roughSkittles is a jewel in the roughSkittles is a jewel in the roughSkittles is a jewel in the roughSkittles is a jewel in the roughSkittles is a jewel in the roughSkittles is a jewel in the rough
If you really want to know if it is running rich or lean read the plugs. I just went through this issue. It can backfire and flame with both. Only true way to find out is read your plugs. Read plug reading 101, it helped me out a lot.
Old 17th April 2013
Ok..timed it dynamically. ..played around with the carb...quick trip around the neighborhood went fine...took it for a longer ride it started missing around 35-40 mph in 3rd so I backed off the throttle which seemed to work momentarily. ...shortly thereafter started lugging and popping (didn't see fire) porcelain was tan on both upper rings on plugs were black..
Old 17th April 2013
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
Because a lean charge burn so slow it is still burning when the valve is opening, that's why.
Tore
