0 S&S MGAL carb
0 Power cones
Last Post: JonesL
0 Arlen Ness Fairing
Last Post: hondo
0 can you tell me why?
0 Coil OK but no Spark??
0 Wheel fitment
5 Tire Pressure?
Last Post: Joe_jeep
6 English newbie
0 Fitting mini apes
Last Post: ivanford
0 .551 Cams in an EFI 1200
0 Forum member mug shots
0 Convert to wide glide front end
Last Post: motorfish
Last Post: Joe_jeep
0 ultima electronic ignition
0 will these fit my 2006 xl 1200c
Last Post: mwXL 2006
0 Noisy
0 93 Sporty Key replacement
0 Wheels
Last Post: NoRemorse
0 Wont shift from 1st to 2nd
0 Pandemic just got wet!
Last Post: Joe_jeep
air cleaner, jetting, s&s, stock bike, teardrop
Old 12th May 2018
davy davy is offline
Sportster/Buell Model: Sportster XL1200 CUSTOM
davy is an unknown quantity at this point
Default s&s teardrop air cleaner on stock bike
Hi,
I know there is a lot of threads about this subject but I didn't find the answer I was looking for.
Does the s&s teardrop air cleaner on a 98 sportser xl1200 stock bike (stock mufflers) needs rejetting or only adjusting the mixture screw is fine ?
Thanks so much
Old 12th May 2018
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 88" 2003.
jkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant future
Originally Posted by davy View Post
Hi,
Thanks so much
they are a good air cleaner!!
If motor starts ok no spiting or farting & after warmed up if it runs ok, should be fine check what pilot jet as if 45 to 46 pj should be right mj about 175 to 185 the motor will tell you when you give it wide open Throttle if it needs more gas.
2003 XL 88"
Old 12th May 2018
thanks for your answer!!
Old 13th May 2018
happy to be able to help.
just thought can also put small washer like is used for electric's, can put washer under head of needle this will bring the richer fuel curve in faster. keep stock spring & do not drill out the vacume hole in the slide. as that stops carb working to design. also if take carb top off, be very very careful . & slow & careful replacing the rubber diapgame and slide. as do not want to pinch the rubber diaphragm .
best of luck & enjoy your riding!!
