Last Post: Jonv
0 Cracked motor mount
0 Sonnax, Timken, Torrington
0 Hack or trike?
Last Post: Firehawk
Last Post: Firehawk
Last Post: Eddieblz
0 Indian FTR Sales
Last Post: xlerate
0 Getting Hammered
Last Post: Bryan83taco
0 jiffy stand question
Last Post: Len PA
Last Post: brixtonanima
0 Spain near Barcelona -anyone know a welder?
Last Post: twohawks
0 Another Sporty ADV Build
0 What got you into bikes?
Last Post: spamer80
Last Post: vagrant318
0 Un-lowering my Super Low
Last Post: Jarlaxle
jurneyman (78), AdO650 (64), xlsport (62), darth (59), mcsmokinp (55), stalkie (55), unleashed66 (54), 66xlch (54), lownslow (48), hrg (46), Ironduke (44)
Old 3 Days Ago
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
American Elites. As good as any of the others and made in America. Law enforcement obviously agrees and they use them aggressively in all conditions.
Old 3 Days Ago
RDHenley's Avatar
RDHenley RDHenley is offline
Sportster/Buell Model: XL883C
Other Motorcycle Model: Street XG500
RDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant future
Originally Posted by c1skout View Post
3) Pirelli MT66 worked well from edge to edge. Never had traction issues in the dry or rain. Even did a 2000 mile 2-up camping trip on this tire and it lasted just over 8000 mi.
You're getting slightly better than I am on the rear tire. I've got about 6500 on my MT66 tires, the front still looks good but the rear is getting near replacement time. Tread grooves are just barely visible in the center on mine, the amazing thing is it's still pretty decent in the rain.
Old 3 Days Ago
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
Originally Posted by Bryan1976 View Post
I always bought the hd Dunlop 401 tires . They did alright for me in dry weather but made me nervous in the rain. A few years ago I bought the American elite h raided Dunlop front and rear. I hated them. A buddy of mine ran a tire place around here and he did the mount and balance for me. I put maybe a hundred miles on them and just hated them. I took my bike back to his place and told him I didn’t like them and just wanted to buy a different set. He asked if he could try something before we changed out the tires I said sure. He pulled the old lead weights off and then bead balanced them. Now I don’t know if it’s just in my head or what but it seemed like a totally different set of tires. I got good mileage out of them and they are good in the rain and stick in the curves well. I have been using them every sense and every set get bead balanced . Call me crazy awe... never mind.
I suspect the difference is due to the tire pressure. To put in the beads he would have to pull the valve core. Perhaps when he inflated the tires for the second time he put in a different amount of air.
Originally Posted by npaisnel View Post
I am a boring xxxx that never rides hard and never pushes the tyres so hard that i can even tell the difference. Just bought a 1993 XLH 883 with only 2500 miles on it and the original tyres.
Yes the side walls have a crack or two in them, but the tread is like new. Yes they are a bit hard, but they do me just fine. I'd not take them out on the highway though for high speed rides.
In the summer last year 2019, I put some Avon Cobra's on my other ride, a 2004 XL, that was still running its original tyres form 2004. I only shaped to new ones as the tread was below minimums.
Can I tell the difference... hard to say ..do they grip a bit better on wet drain covers..maybe but otherwise not really any difference to my sedate riding style.
If they have tread and are circular as opposed to flat at the bottom then they will do me!
I suggest replacing the tires on your 93 as they are likely dry rotted, otherwise your boring ride may suddenly be not so boring
John Wayne - "The Shootist"
Old 3 Days Ago
RDHenley's Avatar
Exactly! When the sidewalls start cracking it leads to the tire suddenly losing it's circular shape. Things get real exciting when that happens.
Old 3 Days Ago
npaisnel npaisnel is offline
Sportster/Buell Year #2: 1993
npaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant future
Ah ! �� They’ll be fine
Promise I’ll change them if I ever take the bike off the island and can go over 30 mph on it
Old 3 Days Ago
ChinCactus's Avatar
So now I had to google Jersey. Very interesting place. Many Sportys there?
Old 3 Days Ago
Most of the HOG members seem to have the bigger Harleys, but yes, there are a few, but I guess most owners are not in the HOG local chapter.
Harleys only really been readily available over here since after about 1990’s I think before that, they may have only got here by private import... but that could well be all of UK too, not sure.
I know that my 1993 bike is a “1HD4CAM..... serial which the first digit indicates US market I think...later UK bikes I believe are all 5HD.... VIN .
There are earlier too, a mate is restoring a pair of WLA’s, and a year or so ago I slung together a box of bits for the owner ... and I really do mean ‘slung together’ It was a two day job, just to see if his box of bits did actually contain a complete bike.
https://youtu.be/hWq0u--mYmU
https://youtu.be/dEqvEupAxPI
There are many many more bikes that, like mine get used occasionally on the island, but are more used when on vacation in Europe.
Like the 1993 I bought the other day. It had sat unused since 2002, hence only 2504 miles on it. I’ve already put 500 on it in the few months I have owned it.
Majority of the HOG chapter are ‘new’ riders... middle aged bankers and business types with money to spend on the big shiny Ultras / Electras etc, There are long term ‘proper’ bikers too, but not so many amongst the HOG members,
See here
http://www.jerseyhogs.co.uk/Rally.html
Old 2 Days Ago
ChinCactus's Avatar
See here
Nice vids! Amazing that bucket O parts turned into a runner! And that it was all there! 99% of the time that's not the case!
Old 1 Day Ago
Was one of the most satisfying jobs in years ��
Over the next couple of weeks bought some new parts, but NONE of those parts changed how it looked ! ��
Battery
Chain
Spark plugs
HT LEADS
New coil
Ignition System DAYTONNA TWIN TECH Mod 1005
Harley sender rotor
VOES Switch
New Carb S&S Shorty E
Fuel tap
Fuel pipe
Oil pipe jubilee clips
Oil & Filter
A pig to ride with no front brake!
He wanted a big ‘open ‘ front wheel look, skinny 21inch 70’s style spoked with small drum. Never found one, ��
As far as I know, it is still the same now,
The owner was the big guy with the beard and no shoes. He had lots of toys. That garage of his has lift to take cars in to the downstairs garage !
Old 1 Day Ago
That big yellow engine you see in the background of one of the videos is a Dorman V8 Diesel, now residing in my mates ‘little boat’
A DeLand US Army tug, originally called ‘Groton’ (ST 1982)
Still not fitted the prop !
http://www.shipspotting.com/gallery/...hp?lid=1795514
http://www.antonygibb.co.uk/elektra/
