0 HSR idle mixture screw
0 First start question
Last Post: Jaime1840
0 It's Glamazon's Birthday!
0 Q cams in 73 xlh ??
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
Old 7th November 2015
lespaul6's Avatar
lespaul6 lespaul6 is offline
Sportster/Buell Model #2: 2002 XL 1200C
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XL1200C
lespaul6 has disabled reputation
Default Homemade axle aduster end plate?
I have a 2002 sportster that had a lowering bracket installed by the previous owner. The bracket is the type that actually bolts into the end of the swing arm taking the place of the stock axle adjustment end plate.
Rather than order and wait, does anyone know if its possible and safe to use a stainless washer to act as the end plate?
advice appreciated!
DaytonaSportster's Avatar
DaytonaSportster DaytonaSportster is offline
Sportster/Buell Model: XL1200c
DaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond repute
I would in a pinch. Just use a hammer and bend the washer around the swing arm so it cant move
http://xlforum.net/forums/showthread.php?t=842245
welshturk's Avatar
welshturk welshturk is offline
Sportster/Buell Model: 1200 Conversion
Sportster/Buell Year: 1991
welshturk will become famous soon enoughwelshturk will become famous soon enoughwelshturk will become famous soon enoughwelshturk will become famous soon enoughwelshturk will become famous soon enoughwelshturk will become famous soon enough
I had the same issue when I removed my lowering brackets. I used a large washer and a smaller washer to spread the force of the bolt and avoid the large washer curving.
It's been like this for the last 6 months. ;-)
lespaul6's Avatar
You guys rock... thanks for the pics! I'm off to ace hardware to get what I need.
einheit 13's Avatar
einheit 13 einheit 13 is offline
Sportster/Buell Year #2: 1997
Other Motorcycle Model: Bonneville America (904)
einheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to behold
Gut the lowering bracket off and use the end plate....
Life may begin at 30, but it really interesting around 150!
Old 8th November 2015
The Crusher's Avatar
The Crusher The Crusher is offline
The Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond repute
Mine had a kit like this. For mine, I just turned the lowering kit, so it acts like a tab and there's holes to mount lights below the rear shocks, if I want.
http://img.jpcycles.com/zoom/701-226_A.jpg
You can't keep a good man down......... unless you tie weights to his ankles.
Old 9th November 2015
welshturk's Avatar
For a neater (more permanent) job, maybe source a larger diameter washers (with the same sized centre hole), grind/cut to around a half inch larger than the swing-arm tube, cut a right angle 'V' at each corner, and peen over the edges.
