0 Dragging clutch
Last Post: Ark OB
0 Starter Relay?
Last Post: andy2175m4
0 Oil pressure switch
0 Carb ???
Last Post: mikethebike61
0 Video - FEED THE BEAST - Your Harley Will LOVE This Mod!
0 Deeded Electrical
0 It's Glamazon's Birthday!
0 What oil temp do you run
0 need help with 68 XLH
Old 13th January 2011
Gone Gone is offline
Gone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud of
How many turns did you back it out when it became loose?
Just shy of two turns. Bike started and seemed to run well, but I just didn't trust it, so I didn't ride it.
BTW since we've been having this conversation, I remembered that I had wondered the same thing you did (did I get everything installed). I took it apart and inspected the assembly and lo and behold everything was there (spring, washer, grommet).
I reinstalled the original adjustment screw, backed it out just shy of two turns and the bike runs well and rides well but still has the cough if I let it run around 2000 rpm then open the throttle. If I stay away from 2000rpm, it doesn't cough.
Old 17th January 2011
Slightly less than two. Same place it is now with the original screw. Looking back at this thread I see that I did try without spring/washer/grommet, but I ordered replacements from John. The replacements didn't improve anything.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
I don't understand that. I've had no problems with my EZ-Just needle being loose. Been using it for nearly 5 years now.
Folkie
South East England Riders
wedge's Avatar
wedge wedge is offline
What's wrong with the stock screw? It weighs less, and it's easy to get a small screwdriver on. Plus once it's adjusted, it's done until the next modification. I'm always trying to get weight off the bike, heck, I haven't had anyting to eat in weeks. In another week, if I live, this thing will fly...
Folkie's Avatar
Brass Nut
The EZ-Just is easy to adjust without a screwdriver, and with my mod I can tell by feel exactly where the adjustment is at. I find this really useful. YMMV
Old 18th January 2011
wedge's Avatar
I'm just messin with ya. The screw looks cool and your mod definitely makes it even easier to use.
Folkie's Avatar
Brass Nut
No, you may be onto something with the weight issue. That, or eat one less French fry. Ever.
snake oil's Avatar
snake oil snake oil is offline
Sportster/Buell Year: 04
snake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nice
I added a short cable and knob and made it very easy to adjust. With the 60 degree temp swings around here I adjust it alot.
Old 19th January 2011
wedge's Avatar
Probably help with the cholesterol too, and that would in turn eliminate a few pounds of fat buildup in the arteries. Dude, you are on to something, I think I'll skip two fries.
wedge's Avatar
Oh, now ya done it, you just opened up "that" can of worms again... LOL
For the record, I tend to agree with you, however; there are a lot of guys in here that will tell you that the CV is self adjusting for temp, altitude, and probably humidity.
