0 Carb starting issue.
Last Post: AudiloveS4
Last Post: bordens
0 80 xl1000 oil not circulating?
Last Post: smilinbrad
0 Wont Fire up!
Last Post: Mission1
0 Coil polarity
0 XR mutt race bike progress
0 show me your sporty next to an old or rural post office
Last Post: Hellbent_4
0 clutch issue
0 1998 883 spits and sputters at around 3000 rpm
Last Post: denguy
0 old style fender skirted
Last Post: Proteus
0 Warm/hot kickstart
0 Rubber mount gas tank part
Last Post: awright2009
0 Top end failure
0 Ebay ****evil knievel bike****
boblaine (85), mike wels (74), GaryR (64), cat5752 (53), Ocbuckeye (50), commandesc (45), vividblack05 (38), north_cack
Old 29th May 2020
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
Default Connectors - O2 Sensors - Tyco 070 Multilock or AMP 1.5 Superseal ? - 2011 xl1200cp
I'm puzzled by the documentation for the electrical connectors on the O2 sensors for my ride..... 2011 xl1200cp
My 2011 HD Service Manuals, Appendix B, are pretty clear. The OEM narrowband O2 sensors, (connector [137] & [138]) specifically call out the connector as:
  • 2-place Tyco 070 Multilock Unsealed (BK)
but the actual connector on my ride looks more like a "AMP 1.5 Superseal". Below is a pic of the female receptacle of the actual connector in use.
I'm wondering:
  • does Appendix B in the manuals have this wrong ?
  • which connector is it really ? ..... the Tyco 070 Multilock or AMP 1.5 Superseal ?
  • am I calling these connectors by the correct name ?
What am I missing ?
Old 31st May 2020
sportsterdoc's Avatar
If your reason for asking is to insure purchasing the correct replacement, you may want to source CVP...or call them with your question.
https://cv-performance.com/Harley-O2-Sensor-12002
Old 31st May 2020
Well, sort of. I'm considering re-routing / moving the cables that feed my Target Tune system. If I pursue making custom length cables, I'll need to re-do the connectors.
Based on additional pics (on various web sites) I've found:
  • no way, the OEM connectors [137] & [138], on my ride, are "Tyco 070 Multilock Unsealed" connectors.
  • I'm 99% certain, the connector really is the "AMP 1.5 Superseal".
  • my only conclusion, the specs on connector [137] & [138] in Appendix B of the 2011 Sportster manuals must be wrong.
BTW, AMP = Tyco, or Tyco = AMP. AMP or Tyco, it seems they are one and the same.
I think it's time to move on. I'll acquire some AMP 1.5 Superseal connectors, & run with that.
Old 31st May 2020
TE Connectivity (TYCO) purchased AMP in 1999 and Deutsch in 2012...so there may be some overlap.
As for your conclusion, I would not expect H-D to use an unsealed connector, especially in that location.
Old 31st May 2020
Good to know. Thx sportsterdoc. That explains why those names seem to be interchanged, at will.
