0 modifying to metal oil tank.
Last Post: Grumpy-Biker
0 Jagg offset oil cooler #4700 removal?
9 Aftermarket Petcocks
Last Post: Bwf347
0 35mm Kayaba Fork Disassemble
Last Post: 1Scooter
0 Motorcycle oils or not ?
Last Post: 1HD4CJM1X4K
Last Post: jammantoo
0 Another spark plug question...
0 Let's study the 77-85 oil pump, parts, and changes and when.
0 Suzuki Lights On 883
0 Might as well join I guess...
Last Post: Island Dude
0 brake upgrade (Can't Bleed)
Last Post: Caustic Dick
0 It's ~Grind~'s Birthday!
Last Post: heyshott 81
0 If I Could Build My Perfect Roadster...
Last Post: 09Nightsterrider
0 getting this 78 back to the way it should be.
Last Post: DirtyHarry68
0 1960 XLCH in the UK
Last Post: 1939WLR
0 Help with my clutch please
0 Another ironhead roadracer
Last Post: BWP 5p
0 Frame mods
Last Post: farmall
0 '71 XLCH owner in Roanoke, VA
Papatony, chedd (73), Nevar (68), nrbase (66), Smokin-Smitty (61), kbfarkas (59), Irondreads (49), Tim97509 (48), CCM0021 (47), wandrur, bikerusn5 (35)
  #1121
Vohnsen Vohnsen is offline
well xxxx me... i just pulled the heads on my engine.. first time.. to see that it got 883 heads on but what seems to be a wiseco 883 to 1200 reverse dome kit on..
this will set me alittle back as far as headwork this vinter.. any tips on what to do? i did plan on just getting a port job and maybe a bigger valve.. but that aint gonna do it with 883 heads right..
https://www.youtube.com/nikolaiownz - Homemade dragbike with Stock XL1200 '98 engine.
Damn I hoped I had found a pair of thunderstorm heads.
After further inspection I found out that they are lightening heads.
I will keep on looking for some better heads.
Sendt fra min EML-L29 med Tapatalk
1.71 valve
Old 4 Days Ago
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Not really planning much this winter except for a few small changes and to freshen everything up. Two step just needs wired up and against most people’s thoughts I’m going back to the stock xb 34 tooth crank sprocket. I’m not going to dish out the cash for aluminum, just put the factory back on and add 4 teeth to the rear. Seems that worked for me better or I could make it work better than the 30 aluminum sprocket. My lack of ability, motivation or whatever in clutch tuning. Looking to have a super consistent 6.20-6.30 bike. This was my first year of really concentrating on Consistency. And it was fun because that’s what I like racing.
Old 3 Days Ago
engine is apart now... planning on getting a bigger 883 conversion valve on my 883 heads and a port job...
i will keep the 883 chamber and run with them stock flat top 1200 pistons to keep my compression high and run this with my SE 497 cams..
Dont know yet how much compression it will give with 883 heads and stock flat top 1200 pistons.. anyone got some info on that?
Old 11 Hours Ago
Tinz's Avatar
Tinz Tinz is offline
Sportster/Buell Model: X1
Tinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant future
I hear ya on consistency, this was my first year bracket racing and I wasn't really consistent at all, just trying to get somewhat comfortable with the bike and go as quick as possible every run. Only got about 50 runs on the bike this season, was starting to get it dialed in but next year will be better.
This long and cold off season I'll be re-wiring the bike, getting rid of the left over stock X1 bundle and multiple splices, get some color coding going on etc.
The oil tank ( half round, looks like an old Slims Fab Farm tank? ) has multiple stress cracks so I either need to buy or fab a new one.
I might paint the bike Camo to represent the Canadian Forces as my wife and I have 38 years combined service.
I'd also like to fabricate a butt stop into my rear fender so I don't have to 'hang on' as much as I am now, not sure how to attack that but will stare at it for a bit in the shop and come up with a plan after some googling.
