0 2020 End of Year Report
0 Secondery Vin tag
0 Better Brakes
0 Halloween 1250 Conversion
0 MS rollers way too tight
0 Northern Canada late 1950’s
0 mainshaft rollers size
0 Sender Unit Part Number
0 Larger Roadster tank for 79-81 Sportster
Last Post: blk80bike
0 Fork oil q
0 mainshaft retaining ring by sprocket
Last Post: ericfreeman
0 XLCR replica in progress
Last Post: spiritof67
0 50 years of wins, the XR750
Last Post: CT XR rider
0 carbs?
0 Paradise Weather Service
0 my sunday driver...
0 Roadster - No Key Start
Last Post: exexpat93
0 Difference between 2-1 and 2-2 exhaust
0 tappet/blocks fitment by year
2 My 1275 Hammer Conversion..
0 What engine oil do you use?
Last Post: Akdawg
Old 14th August 2019
ratsnest ratsnest is offline
ratsnest is an unknown quantity at this point
Default mini speedo w/ indicators
Still a super noob here, trying to figure out if this thing will even work for me:
https://www.dimecitycycles.com/speed...-diameter.html
It says that it's 'universal' and I understand that i'll have to figure out how to wire the thing up, but with the stock wheels it should be the correct ratio, right? I have a 1997 1200C.
I really hate the stock setup and want to clean this up so I can get riser-less bars... Is there anything special i'd have to do to get this to work with my model?
thanks
NLXL's Avatar
NLXL NLXL is offline
These will only work if your current speedometer is driven by your front wheel by a speedometer cable. I think 1994 was the last Sportster model with a mechanical front wheel driven speedometer.
However, you can relocate you current speedometer to the side. To the frame tube or to the left fork leg.
here's a very expensive example:
https://jokermachine.com/products/sp...be-clamp-black
...or try eBay for a cheaper one...
https://www.ebay.co.uk/itm/39mm-16-S...-/282534786201
Just google a bit on 'side mount speedometer sportster'. And maybe someone here with a side mounted speedo can help you with it.
NLXL's Avatar
Oh...and of course these guys can help you too! Well known on this forum.
https://www.youtube.com/watch?v=PYJyDmHpk38
Old 15th August 2019
That joker option looks pretty slick compared to the 'cheapo' version... Either way it looks like i'll have to buy some parts since i'm on a 'c' (backing plate and rubber mounts)... Not sure how my LEDs break down compared to the standard sportster indicators, but if I went with the cheaper option I'd likely have to also buy more 'standard' sportster parts to make it work.
Thanks for the tips.
NLXL's Avatar
Before you buy anything. Maybe it's a good idea to contact DK Custom on this forum and PM them on what you have now and what you want it to be. Perhaps they can give you more tips on what to buy etc...maybe they have something cheaper than the joker option(?)
DK Custom
http://xlforum.net/forums/member.php?u=75570
DK Custom
I found their FAQ it looks like it'd be around ~30-40 more $$ just to get the extra parts I need since the LEDs don't align. At that price point i'm looking at the Joker machine as I think it looks a bit sleeker (also prefer the fork mount). Will reach out to them to confirm though.
NLXL's Avatar
Maybe they can give you some discount being on this forum(?). That joker part definately looks sleek. Well, when you made your choice and it's installed I'm sure you will show us the pics.
cheers!
Old 25th August 2019
crb2855's Avatar
crb2855 crb2855 is offline
Sportster/Buell Model: 1986 Sportster
Sportster/Buell Year: 1986
Other Motorcycle Model: 1979 FXEF 80
crb2855 is an unknown quantity at this point
Perhaps you could use your phone mounted on the bars with a speedometer app, I've done that it's seems pretty accurate.
