0 so it's officially ended
0 Starter for an XLCH
Last Post: 72 Ironhead XLH
0 Xr750
Last Post: seajay
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Randy_rots
0 blocked main jet air bleed screw
Last Post: T_worth
0 Runs great - stalls on clutch pull
Last Post: tedcool
Last Post: rivethog
Last Post: thefrenchowl
0 Now I did it. Feel my pain
Last Post: FiftySixer
Last Post: owlsplace
0 100 vs 110 front tire
0 Sportster drag bike
0 Curious question on E85
Last Post: Nicktater
0 no handlebar controls
Last Post: Samedward
0 Anyone tune for and use E85?
0 E85
Last Post: XL Dane
0 CV Carb hesitation
Last Post: ReddTigger
0 Xl???
Last Post: SLW210
Old 24th August 2020
BTD BTD is offline
Sportster/Buell Year: 1984
BTD is an unknown quantity at this point
Default 84 top end disassemble
Hey all,
Having a hard time getting the last two bolts off the rear cylinder head. The frame is too tight to the head to allow an extension for my wrench, and its hard to get enough leverage with a universal joint. Anyone run into this issue?
Do I need to remove the engine from frame to do this? I want to keep it mounted as long as possible to help with the disassembly.
Thanks!
Old 25th August 2020
1Scooter 1Scooter is offline
Sportster/Buell Model #2: 2004 XLH1200Custom
Other Motorcycle Model: 2007 FXDB
1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold
Might wanna remove the rocker box fasteners and wiggle it around for clearance. Gotta be the right head bolts. On my 77 and past 75 & 72, I used a 3/8" ratchet, 8" extension, swivel joint and the socket . . . from the left side of the engine. Works all the time.
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
BigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond repute
Do you have 12-point head bolts? My favorite tool for getting those off is a regular wrench with a cheater bar.
doodah man's Avatar
i had good luck with a wobble extension rather than a swivel joint, and +1 for removing the rocker bolts to make more room.
Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Go through. The pushrod side with a boxed end wrench to break it loose.
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
rocker box is going to come off anyway.get the bolts loose,pull up the ones you cant get out,make sure the box is loose,hold them up,and wiggle it off.then you can get to the head bolts.put it back together the same way you took it off holding the center bolts up,wigglein like a pole dancer,haha.torque the headbolts with the boxes off making sure you tighten them in stages up to 60 pounds.the thin copper ones are the best and spray both sides with Permatex copper spray a gasket both sides.works for me
Old 4 Weeks Ago
like Mike said remove the pushrods and you can use a box wrench on the right from the side.once you've done this you'll wonder why people fool around with swivels etc.from the top.
Old 2 Weeks Ago
BTD BTD is offline
THANKS FOR ALL THE ADVICE! JUST TOOK SOME FINESSE AND ONLY ONE SNAPPED SWIVEL.
SOME PROGRESS PICS. NOW ONTO BOTTOM END.
Old 2 Weeks Ago
BigMek's Avatar
Oh hey, you have the retrofit sprocket nut. Try to save that if you can - nobody makes them anymore.
To help with all that rust, a 50/50 mix of ATF and Acetone supposedly works as well as or better than commercial penetrating oils.
Old 2 Weeks Ago
Originally Posted by BigMek View Post
... To help with all that rust, a 50/50 mix of ATF and Acetone supposedly works as well as or better than commercial penetrating oils.
Machinist's Workshop magazine in their April 2007 issue...
https://www.practicalmachinist.com/v...ng-oil-196347/
