0 100 vs 110 front tire
Last Post: bill smith
0 old parts
Last Post: FiftySixer
0 Starter for an XLCH
Last Post: Imaginearat
0 so it's officially ended
Last Post: Nicktater
0 Xl???
0 Sportster drag bike
Last Post: Zip1
Last Post: robbie202
Last Post: ericfreeman
Last Post: FrankGS
0 '66 XLCH VM38 Conversion
0 CV Carb hesitation
Last Post: owlsplace
0 Tuners
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Old 3 Weeks Ago
Hippysmack's Avatar
Originally Posted by JSH View Post
Help?
I pulled the carb again and checked float needle and seat. It was in correct adjustment and sealed easily when the float was gently lifted. I checked for a leak in the bowl overflow tube - perfect seal, even under air pressure.
How did you check for a leak in overflow tube... what procedure?
Old 3 Weeks Ago
Bigshankhank Bigshankhank is offline
Sportster/Buell Model: Ironhead Hardtail
Other Motorcycle Model: KTM Duke 390
Other Motorcycle Year: 2015
Bigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant future
Quick answer would be to take the float bowl off of the carb and fill it with water, if water starts coming out of the overflow before the water level reaches the opening in the top of the tube, there is a crack in it. Heck, IIRC the opening in the top of the tube should actually be higher than the top of the float bowl so it shouldn't flow out at all with this method.
What I do (not that anyone asked) with needle seats is to cut a cotton swab in half, stick the cut end in the collet of my dremel, put some metal polish on the cotton end and polish the brass seat with it. You will need to shoot some cleaner through the aperture to get any polish out of it but it leaves the brass super clean and shiney.
Old 3 Weeks Ago
JSH JSH is offline
Sportster/Buell Year: 1979
JSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of light
I suspected the overflow tube leaking, so tested it under pressure. It held fine. The tube is not cracked or corroded.
The accelerator pump is correctly installed.
Mike's idea about the fuel leaking around the float needle insert is interesting, and I'll check it. It's not leaking a little though, but a lot - just as if the float is hung up, but it's not.
I looked around for a new stock carb, bowl or float with no success. Anyone know of these for sale anywhere?
Old 3 Weeks Ago
JSH JSH is offline
The needle seat is plastic or bakelite, not brass like the old ones. I cleaned and honed it gently. The procedure for testing the float bowl was, as you said, filling it with water. It did not leak. Yes, the tube extends above the bowl top, so that is not an issue. I even put compressed air to both ends of the overflow circuit while the water was still in the bowl, while it was gently chucked in a vise and level. If there was a leak anywhere, it should have bubbled with the air pressure. I tried two different needles, both clean and apparently free of defect.
Old 3 Weeks Ago
tedcool tedcool is offline
Sportster/Buell Model: XLH 1100
Sportster/Buell Year: 87
Other Motorcycle Model: KTM 450 XC-W
Other Motorcycle Year: 2014
tedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud of
Is it possible the float just isn't...floating?
Mine looks like some sort of closed cell foam. If the foam degraded and absorbed some fuel, or some of the goo you cleaned out of the carb, maybe it's too heavy?
Maybe someone can weigh a good one, or measure how high it floats above the fuel.
Can you get a replacement float?
87 XLH 1100
Old 3 Weeks Ago
JSH JSH is offline
I tested the float for buoyancy for about 15 minutes. It's made of hard hollow plastic. I mmersed it in a cup of water repeatedly, and it floated very high without ever becoming saturated at all. I did wonder if a water test is truly effective, as gas is thinner than water and can get into places water cannot. But, upon removal from the carb there is no gas inside it, and I can see no apparent holes.
Old 3 Weeks Ago
Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Sounds like you’ve ruled out the float itself. Install float and leave bowl off. Close it by hand and see if any fuel is passing through somewhere.
Old 3 Weeks Ago
I like Mike's idea.
Just to rule it out:
How, exactly, did you set the float level? What technique and measurement?
Old 3 Weeks Ago
It might be helpful for you to post some pictures of THIS float bowl & also several from different angles of the float mounted on the carb, the float valve needle & the valve seat...
Nice clear pics...
Old 3 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
whoops ! Wrong thread !
