0 100 vs 110 front tire
Last Post: bill smith
0 old parts
Last Post: FiftySixer
0 Starter for an XLCH
Last Post: Imaginearat
0 so it's officially ended
Last Post: Nicktater
0 Xl???
0 Sportster drag bike
Last Post: Zip1
Last Post: robbie202
Last Post: ericfreeman
Last Post: FrankGS
0 '66 XLCH VM38 Conversion
0 CV Carb hesitation
Last Post: owlsplace
0 Tuners
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Old 3 Weeks Ago
Tipofthelake Tipofthelake is offline
Sportster/Buell Model: XLS 1000
Sportster/Buell Year: 1979
Sportster/Buell Year #2: 1973
Other Motorcycle Model: Electraglide
Other Motorcycle Year: 2007
Tipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to all
If you gently lift the float until the needle just seats and turn the petcock on does gas come out? Something has to be keeping it from getting a good seal. If that works there has to be some binding somewhere once assembled or the float level has to be set too high. If you purposely set the level too low does it seal? Just a couple of quick things to try before you consider replacing things trying to fix the issue. Also, have you tried standing the bike up before turning the gas on? That might be an easy way to see if it's binding as if it works level but not on the side stand something is off.
Old 3 Weeks Ago
Rodzilla's Avatar
Rodzilla Rodzilla is offline
Sportster/Buell Year: 1976
Sportster/Buell Model #2: Buell XB12S
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Too many to mention
Rodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really nice
Originally Posted by tedcool View Post
Is it possible the float just isn't...floating?
Mine looks like some sort of closed cell foam. If the foam degraded and absorbed some fuel, or some of the goo you cleaned out of the carb, maybe it's too heavy?
Maybe someone can weigh a good one, or measure how high it floats above the fuel.
Can you get a replacement float?
I had this on an ElCamino once.... drove me to the point of taking it to an old-timer/expert. When I picked up the truck I asked, "what was it?" He said, "The float was bad......". I told him I had personally checked the float and it was not taking on gas..... he grinned, went and got the float, shook it to show it had no gas in it... but when he pressed the plastic float material with a screwdriver it wept gas.....
So, tedcool is correct, a tiny change in the float weight can throw your float bowl fuel level off, and not just a little.... If it passes the other tests mentioned, weigh the float and then put it under a drop cord light and get it hot for a couple of hours.... then reweigh it.
Old 3 Weeks Ago
tedcool tedcool is offline
Sportster/Buell Model: XLH 1100
Sportster/Buell Year: 87
Other Motorcycle Model: KTM 450 XC-W
Other Motorcycle Year: 2014
tedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud oftedcool has much to be proud of
You will need a very sensitive scale to do this. A kitchen scale with 1 gram resolution probably won't work. More like .01 gram resolution would be good.
Most people don't have a precision scale ( maybe certain...vendors...).
I bought one to weigh out hardener for small amounts of epoxy needed for boat repair. Amazon to the rescue!
I suppose you might find something at the local 'head shop'.
Good luck!
87 XLH 1100
Old 3 Weeks Ago
Rodzilla's Avatar
Good luck!
"Head Shop".... I am not familiar with that term.....
Old 3 Weeks Ago
Shop that sells drug accessories
Old 3 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Mike, where were you in the 70's ?
And not drugs, that would be illegal. Just for aromatic herbs.
Old 3 Weeks Ago
bill smith bill smith is offline
Sportster/Buell Year: 1971
bill smith has much to be proud ofbill smith has much to be proud ofbill smith has much to be proud ofbill smith has much to be proud ofbill smith has much to be proud ofbill smith has much to be proud ofbill smith has much to be proud ofbill smith has much to be proud ofbill smith has much to be proud ofbill smith has much to be proud ofbill smith has much to be proud of
If you need parts ,tell me what and send your address to finework74@gmail.com. When you receive 'em send me whatever it cost for me to ship it. I have your float and prolly whatever else you need.
Old 3 Weeks Ago
GaryanOdinson's Avatar
GaryanOdinson GaryanOdinson is offline
Sportster/Buell Model: 1984 xlch
Sportster/Buell Year: 1984
GaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really nice
On The Kehin You Hit these Two Right ON Took Me a while to relise,Float Binds when Bike on Side stand I always start Bike Level After it warms i take choke off and its fine..I wondered why every time the bike started right up,and i put it back on the stand,it would cough,spit,the smooth idle would diapear..i'de pull it up level and it would smooth right out. Those Floats kick Sideways binding, Or It Does on mine Not sure there all the same But I'de Bet Close. Float hight Correct,Start Bike Level..Been a good year for me and e84
Old 2 Weeks Ago
mikethebike61's Avatar
I ran a 34mm from a 1980 on my 77 xlch for decades
75 slow jet and 165 main was PERFECT....
I could idle it down to 450 rpm
Idle was so good at 800-900 it almost no longer sounded like a H-D
JSH JSH is offline
JSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of light
