0 Xl???
0 Now I did it. Feel my pain
Last Post: seajay
0 My '96!
Last Post: 1200CustomHD
0 Sportsters in movies and TV
0 Xr750
Last Post: SLW210
0 S&S Super E Carb
0 Oil not returning to tank
0 100 vs 110 front tire
0 Fair price for used parts
Last Post: rivethog
0 Mikuni - hangin revs
0 so it's officially ended
Last Post: robbie202
0 New to me '08 1200R
Last Post: PhiRR
0 TC88A update ?
Last Post: HOG63
5 Dynatek DSPT-1 ?
Last Post: HOG63
0 Riding music
Last Post: CCC
Last Post: slojoe631
Last Post: SD_Mike
Last Post: randy3934
Last Post: Greasyman
0 old parts
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
  #31
JSH JSH is offline
Sportster/Buell Year: 1979
JSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of lightJSH is a glorious beacon of light
Problem solved. I had to burnish out a pit the float needle pin gouged into the brass tang on the float. I replaced it with a later model needle that has a broad base and no little pin, which will wear better. I found a countersink the same angle as the float seat and gently refaced it by hand with a bit of toothpaste. I then made a test rig from a little funnel, some fuel line and a water glass that was the same diameter as the float bowl. I set the carb on it so the float buoyed as it would in normal use, shutting off the fuel flow with the needle. I then poured Coca-Cola into the funnel (it's all I had at the time! Use food coloring if you have it!) and waited a while to see if it leaked. I lifted the carb a tad and the brown Coke flowed into the glass. Worked great. I also found hairline cracks in the outer plastic fuel fitting, so pulled that and pressed a new solid brass one in. For some reason testing with compressed air didn't show the problems, but this rig did.
I took the thing out for a test ride and pegged the speedo. It runs like a brand new bike. I believe the owner wants to sell it for $3,000, if anyone is interested. It's a bit small for me, but this thing is like new if anyone wants it. It deserves a nice home.
Thanks to all for your help and ideas.
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
What a great idea !
A clear float bowl !
XL1275 XL1275 is offline
Sportster/Buell Model: XL1275 Roadster
XL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud of
Cool. Man someone can snag that for 3K is going to have a nice one. Thanks for the write up
