0 Xr750
Last Post: seajay
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Randy_rots
0 blocked main jet air bleed screw
Last Post: T_worth
0 Starter for an XLCH
Last Post: Imaginearat
0 Runs great - stalls on clutch pull
Last Post: tedcool
Last Post: rivethog
Last Post: thefrenchowl
0 Now I did it. Feel my pain
0 so it's officially ended
Last Post: FiftySixer
Last Post: owlsplace
0 100 vs 110 front tire
0 Sportster drag bike
0 Curious question on E85
Last Post: Nicktater
0 no handlebar controls
Last Post: Samedward
0 Anyone tune for and use E85?
0 E85
Last Post: XL Dane
0 CV Carb hesitation
Last Post: ReddTigger
0 Xl???
Last Post: SLW210
Old 2 Weeks Ago
Yochstein's Avatar
Yochstein Yochstein is offline
Sportster/Buell Year: 1984
Yochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud of
Default Did the IH have a neutral indicator light?
My bike came to me with the dash and signal lights cut off. I am in the final stages of getting it 100% back together including the proper indicators. I purchased LED replacements to fit the 3 holes in my gauge mount for Hi-Beam, Neutral, and Oil Pressure. I glanced at my wire diagram and noticed that there is not a neutral indicator light mentioned. Can anyone verify that the Late 1984 model sold without one? I don't need an indicator to know I'm in neutral, I just want to have it there if it was supposed to have one from the factory.
Thanks!
Old 2 Weeks Ago
Yellowstone Kelly's Avatar
Ironhead Rider
Sportster/Buell Year: 1982
Sportster/Buell Year #2: 1969
Other Motorcycle Model: FLSTC
Other Motorcycle Year: 1996
Yellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant future
No, not on Ironheads.
I've read that neutral lights on Sportsters first appeared in 1986, but I can't personally confirm that.
Old 2 Weeks Ago
Hippysmack's Avatar
According to the wiring diagrams, it was '91 when they first appeared.
Old 2 Weeks Ago
Yochstein's Avatar
Thanks guys, I appreciate it. I now will have a green light to use somewhere else if needed.
Old 2 Weeks Ago
Tipofthelake Tipofthelake is offline
Sportster/Buell Model: XLS 1000
Sportster/Buell Year: 1979
Sportster/Buell Year #2: 1973
Other Motorcycle Model: Electraglide
Other Motorcycle Year: 2007
Tipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to all
Wouldn't that spot be for the generator?
Old 2 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
How would anyone know what gear they are in, including neutral, without a gear indicator ?
I mean, like, you'd have to check Facebook to see what gear your in.
Yeah, the blue is Hi-Beam, Red is oil and Green is generator
Old 2 Weeks Ago
NLXL's Avatar
NLXL NLXL is offline
XLX-61, 1984
GEN - BEAM - OIL
Sportsterpedia
Scientia potentia est
Old 2 Weeks Ago
Parker 1000 Parker 1000 is offline
Sportster/Buell Model: Xlh/Xlch
Sportster/Buell Year: 1976
Parker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to behold
All I know is that on my 1976 XLH, it is sometimes a challenge to even find neutral.
Old 2 Weeks Ago
NLXL's Avatar
On Ironheads I learned to switch to neutral just before a complete stand still. Always worked
Old 2 Weeks Ago
LLOYD883's Avatar
LLOYD883 LLOYD883 is offline
Sportster/Buell Model: xl883c
LLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant future
Hey, my rubbermount 2005 doesn't have one either. Well not for the past few years anyway.
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
