0 Xr750
Last Post: SLW210
0 Xl???
Last Post: SLW210
Last Post: canoli
0 S&S Super E Carb
0 Oil not returning to tank
0 Sportsters in movies and TV
Last Post: dodgetrucken
0 100 vs 110 front tire
0 Fair price for used parts
Last Post: rivethog
0 Mikuni - hangin revs
0 so it's officially ended
Last Post: robbie202
0 New to me '08 1200R
Last Post: PhiRR
0 TC88A update ?
Last Post: HOG63
5 Dynatek DSPT-1 ?
Last Post: HOG63
0 Riding music
Last Post: CCC
Last Post: slojoe631
Last Post: SD_Mike
Last Post: randy3934
Last Post: Greasyman
0 Now I did it. Feel my pain
0 old parts
0 Digital speedo from street bob on a sporty?
Last Post: yelladox
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
Old 2 Weeks Ago
Yochstein's Avatar
Yochstein Yochstein is offline
Sportster/Buell Year: 1984
Yochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud of
Originally Posted by NLXL View Post
XLX-61, 1984
GEN - BEAM - OIL
Since I’m a late 84 with no generator, makes sense as to why there was a blank in the middle spot. The PO cut the dash and signal wires in an crappy attempt to minimalize the bike as a bar hopper. Luckily I came along and rescued it from a certain future as a pile of parts.
Old 2 Weeks Ago
NLXL's Avatar
NLXL NLXL is offline
That certainly makes sense. Maybe you can use the green one as a turn signal indicator? (if there are any turn signals on the bike).
Sportsterpedia
Scientia potentia est
Old 2 Weeks Ago
hd said if it fits, ship. quality control was an issue, a thing that AMF brought to the table, but took some time, old farts do not like changes.
my 74 had oil and gen.
back to target, my ch had issues with shift also, what will help greatly is to blue print the tranny. when i adjusted to the minimum allowable clearances, made a HUGE diff, no more clunk and slides into gear and you swear it did not. hd gear dogs sucked as it was basically drag and drop. the counter shaft is a little tricky but doable through the oiler plug hole. best to measure every thing first so you know what direction to go. some of the shims were a trick to find.
it is well worth the effort if it bothers you, i just had bird in hand since i was in there.
Old 2 Weeks Ago
Yochstein's Avatar
I installed the turn signals on the bike again. I considered a signal light but since I have to hold the button down for the signals to function and turn off when I release, there really wouldn't be any need for an indicator since there's no mistake of leaving them on.
I may leave the middle spot open for a future toggle switch if needed.
