Last Post: CCC
0 Starter for an XLCH
Last Post: mickey t
0 Now I did it. Feel my pain
Last Post: motorfish
0 so it's officially ended
Last Post: Proteus
0 Oil not returning to tank
Last Post: poy6r
0 Xl???
0 Xr750
Last Post: seajay
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Randy_rots
0 blocked main jet air bleed screw
Last Post: T_worth
0 Runs great - stalls on clutch pull
Last Post: tedcool
Last Post: rivethog
Last Post: FiftySixer
Last Post: owlsplace
0 100 vs 110 front tire
0 Sportster drag bike
0 Curious question on E85
Last Post: Nicktater
0 no handlebar controls
Last Post: Samedward
0 Anyone tune for and use E85?
0 E85
Old 2 Weeks Ago
Jeff.W. Jeff.W. is offline
Sportster/Buell Model: Xlh
Sportster/Buell Year: 1979
Jeff.W. is an unknown quantity at this point
Default 1979 xlh brake pedal woes
The hole for the pinch bolt on my brake pedal is stripped. The pedal is pretty beat and I think a past owner rigged up a different pedal anyway, so I’m trying to find a replacement rather than fix it. Finding one for a ‘79 is tough. Sites are sold out, and I couldn’t find anything on eBay that I was 100% sure would work.
I was wondering if anyone knows if pedals from other years would fit a ‘79. Idk if mounting shaft bore sizes changed from year to year or how many splines are on a ‘79 shaft. I’d happily by one from another model year, but I have no idea if they’ll fit or not. Any guidance would be appreciated!
Old 2 Weeks Ago
XL1275 XL1275 is offline
Sportster/Buell Model: XL1275 Roadster
XL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud of
That or a helicoil
Old 2 Weeks Ago
harley506d's Avatar
Sportster/Buell Model: 1200c
Drill it out and use a nut and bolt?
Old 2 Weeks Ago
Tipofthelake Tipofthelake is offline
Sportster/Buell Model: XLS 1000
Sportster/Buell Year #2: 1973
Other Motorcycle Model: Electraglide
Other Motorcycle Year: 2007
Tipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to all
Yeah, all those sites have been listing the aftermarket pedal but showing it out of stock for years now, which is really annoying when it shows up in a search. The pedal is only 1979 and 1980 I believe, and is quite different from the design used in other years. I believe it is possible to switch out the cover parts from a 1981 to switch the style out, but honestly those parts seem to be hard to come by also.
If you can put a through bolt on it that is probably your best bet.
Old 2 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I think the 79 is one year only.
if you replace the sprocket cover you can use the 80 version.
Old 2 Weeks Ago
There it is. I was posting before drinking coffee, which is always s bad idea. It's the 1980 parts I meant, not 81.
Old 2 Weeks Ago
mikethebike61's Avatar
I replaced my 1977 XLCH sprocket cover with a NOS 1979 cover and all the NOS pieces needed for the M/C.....did not need to change anything to do with the pedal
Old 2 Weeks Ago
If you are not doing a restoration I would sell the 79 only parts on eBay (don't give them away) and switch to the later setup.
This allows using normal pipes and eliminates the monkey motion on the 79 brake. I think the same asshole designed that as that designed the crossover shifter linkage!
The later brake setup is plentiful and easy to find.
The later oil tanks bolt in and hold an extra quart of oil also.
Old 2 Weeks Ago
Lots of great info here, thank you all so much! Yes, the through bolt is my quick fix option and probably will stay that way for a while. But like I said, the pedal is beat up (road rash, chrome peeling) so I would like to eventually replace it.
Old 2 Weeks Ago
And no, no restoration happening with this one. It’s been a little bastardized before getting to me, so I just want to clean it up a bit. Here’s a photochop I did of the direction I’d like to go...
