0 Xl???
Last Post: 1200CustomHD
0 Digital speedo from street bob on a sporty?
Last Post: yelladox
0 Mikuni - hangin revs
Last Post: Piccollob12
0 Starter for an XLCH
Last Post: Imaginearat
0 Hello from LA area
Last Post: initiatebjj
0 so it's officially ended
0 Oil not returning to tank
Last Post: 1Scooter
Last Post: Nicktater
Last Post: The Doctor71
0 blocked main jet air bleed screw
Last Post: RussW
0 old parts
Last Post: bill smith
Last Post: Greasyman
0 Now I did it. Feel my pain
Last Post: motorfish
0 Xr750
Last Post: seajay
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Randy_rots
0 Runs great - stalls on clutch pull
Last Post: tedcool
Last Post: rivethog
Last Post: FiftySixer
0 100 vs 110 front tire
0 Sportster drag bike
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
Old 2 Weeks Ago
Yochstein's Avatar
Yochstein Yochstein is offline
Sportster/Buell Year: 1984
Yochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud of
Default Late 84 Tachometer signal wire
I put my original tach back on the bike today. The pink wire is the signal wire for that tach that I know runs to the coil. My question is what side of the coil catches the signal? Does it matter which side gets the wire? My coils are not OEM with a blade terminal for this wire. These are from Pertronix which is the same place I got my ignition system. I don't want to risk frying anything if possible.
Old 2 Weeks Ago
cazz1000 cazz1000 is offline
Sportster/Buell Model: xlx
left side if 2 pole,,,,,,,,,,,,, or 3 pole,,,,................if setting it up with just the pink wire,,,,, left side of the coil,, all the way,,,,,,,,,,,,, 2 or 3 pole,,, i run on the left side of my ultima iggy 3 pole coil,,,,,,,,,,,,,,, and left side on the dyna ,s 2 pole coil,,,,negative side,,,,,,,,,, left side,,,,,,,,,,,,,with the spark plug terminals on the coil,,,,,,,,,,,,,,,, facing you,,,,,,,,,,,,,
Old 2 Weeks Ago
Yochstein's Avatar
I dug up my compufire instructions. There are 2 wires from the unit to the coil. Black to one pole and red to the other. The red wire shares the connection to the ignition switch.
Old 2 Weeks Ago
You're using a Dual-Fire setup - Right?
Keyswitch is Power TO the Coil & RED wire extends that Power TO the Ignition Module...
Black wire FROM the Ignition Module is the COIL TRIGGER, which is where you want to take off for the Tachometer (using the PINK Tach Wire)...
Old 2 Weeks Ago
Yochstein's Avatar
Yes, it is a dual fire module. Thank you very much for clarifying.
Yochstein's Avatar
It worked like a charm. Thanks so much.
Glad to be of help - Enjoy the ride...
