0 Sportsters in movies and TV
0 Xr750
Last Post: SLW210
0 Xl???
Last Post: SLW210
Last Post: canoli
0 S&S Super E Carb
0 Oil not returning to tank
0 100 vs 110 front tire
0 Fair price for used parts
Last Post: rivethog
0 Mikuni - hangin revs
0 so it's officially ended
Last Post: robbie202
0 New to me '08 1200R
Last Post: PhiRR
0 TC88A update ?
Last Post: HOG63
5 Dynatek DSPT-1 ?
Last Post: HOG63
0 Riding music
Last Post: CCC
Last Post: slojoe631
Last Post: SD_Mike
Last Post: randy3934
Last Post: Greasyman
0 Now I did it. Feel my pain
0 old parts
0 Digital speedo from street bob on a sporty?
Last Post: yelladox
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
Old 2 Weeks Ago
Greasyman Greasyman is offline
Greasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really nice
Default '74 hard to start, won't idle
Bike will start and rev but quickly dies and won't idle. Is also finicky about starting, likes one twist of the throttle and no choke.
Wondering what my plan of attack should be. Is it more likely to be the carb or ignition?
Bike has sat for long time, probably over a year, so maybe it has a gummed up carb (Bendix).
Ignition is Dyna S, so unless someone messed with it it's probably ok.
Plugs are new.
Bike is quite clean. Was one owner and well cared for until owner died. I bought it from a guy who owned it briefly and messed with it a bit. I've had it for a few months, it's been sitting all this time and now I'm trying to get it to run properly.
What can I do about a gummed up carb? I've never had that problem. Will running some Gumout thru it help, or will I have to take the carb apart to clean it?
Old 2 Weeks Ago
From the Stickys...
Cleaning a Carb
http://xlforum.net/forums/showthread.php?t=185361
Old 2 Weeks Ago
Your bike must idle well in order to start well.
Sounds like you need to chase the boogers out of that carb.
Just cleaning the low speed jet may fix it.
Old 2 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
OK. Here's another can of worms.
For $59 you can buy a "fake" S&S Super E off Ebay.
It bolts straight on and if you pick the correct option when you buy one it will already be jetted for your bike.
If it works well you have two choices. Stick with the new "fake" or rebuild your old one.
But bolting on a new correctly jetted carb will tell you if the problem is somewhere else.
Old 2 Weeks Ago
doodah man's Avatar
My favorite carb cleaning method, dismantle, soak in berryman's for a day or night, pour a pot of boiling water through every hole and orifice in the carb body, dry and reassemble.
Old 2 Weeks Ago
Guidorey Guidorey is offline
Sportster/Buell Year: 1959
Other Motorcycle Model: Ariel Square Four
Other Motorcycle Year: 1951
Guidorey is just really niceGuidorey is just really niceGuidorey is just really niceGuidorey is just really niceGuidorey is just really niceGuidorey is just really niceGuidorey is just really niceGuidorey is just really niceGuidorey is just really niceGuidorey is just really niceGuidorey is just really nice
And in addition adjust your pushrods, take the fuel tap off and make sure the gauze filter and fuel line is clean, adjust your float bowl level properly after cleaning the carb.
