0 100 vs 110 front tire
Last Post: bill smith
0 old parts
Last Post: FiftySixer
0 Starter for an XLCH
Last Post: Imaginearat
0 so it's officially ended
Last Post: Nicktater
0 Xl???
0 Sportster drag bike
Last Post: Zip1
Last Post: robbie202
Last Post: ericfreeman
Last Post: FrankGS
0 '66 XLCH VM38 Conversion
0 CV Carb hesitation
Last Post: owlsplace
0 Tuners
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Martysf's Avatar
Martysf Martysf is offline
Martysf is a name known to allMartysf is a name known to allMartysf is a name known to allMartysf is a name known to allMartysf is a name known to allMartysf is a name known to allMartysf is a name known to allMartysf is a name known to allMartysf is a name known to allMartysf is a name known to allMartysf is a name known to all
Default Gas flow - overflow tube
New issue - steady flow of gas from run off tube at bottom of carb on my 83xlx whether on run or reserve on petcock. And I mean steady flow!!
Shakes Dave - is this your warning to get a Pingel haunting me??
sml1226 sml1226 is offline
Sportster/Buell Model: XL1275R
Float or needle related, not the petcock. Pull the bowl, check the seat on the float needle. If that's worn out, you need a new one. Check that the float actually floats as well. If it's cracked or has a hole in it, it'll just fill with gas and stay down. If it doesn't seat or the float doesn't actually float, the gas just keeps flowing until you fix it or you're out of gas.
Martysf's Avatar
Thank you!
Bluto Bluto is offline
Other Motorcycle Model: Norton 850 Commando
Other Motorcycle Year: 1973
You might want to carry a small fire extinguisher until you are SURE you have that fixed...had a float problem on my Norton and it caught fire (got lucky and was able to put it out with my gloves but easily could have lost the bike)
Martysf's Avatar
Good point Bluto thank you. It def did occur to me that it could be a dicey start
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
absolutely brother.hopein this smoke goes away soon.hope everythings good with you
