Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Era Specific and Model Specific > XR Sportster Motorcycle Talk - XR750, XR1000, XR1200
XR Sportster Motorcycle Talk - XR750, XR1000, XR1200 For XR Sportsters: XR750, XR1000, XR1200
0 Hard to find Neutral
0 MagnaFlow Riot collector
Last Post: Conan
0 Can't clear unread messages
0 This place still sucks!!!
0 0Salt Flat Sporton
0 Tire Pressure 1979 XLH
Last Post: ThenCameHarry
0 Upgrade proof, evidence backed, High Flow Air Filter/intake for EFI 883/1200
Last Post: Ranchero50
Last Post: ZCarFan
Last Post: maltesefalcon
0 WTB - 66 xlch rocker box parts
0 DK Customs Air Intake
Last Post: Blacky
Last Post: Turbo Sporty 48
0 Woke, cancel culture...
0 83 XLH w/Velorex 562
0 WTF Happened
0 Can you ID this bike?
0 Shady shifter shaft
Last Post: Captain Johnny
4 Rear Lighting WIRING help
Last Post: Cosmo Kramer
Last Post: SCarty
0 Video - Does your bike REALLY need an oil cooler?
Last Post: Blacky
Last Post: XL_1200C
0 Best seat for long rides
0 Starter motor brushes? (UK)
Last Post: Loony
0 Chinese S&S carbs
0 Rear shocks ?
Last Post: Wiktor
0 New to me 1975 sporster xlh
Mr.Gordon, rayzer13 (58), GrumpyCoyote (52), billet93 (48), beast1 (47), Barney_rubble23 (47), DDT (43), mgaworecki (42), superman5a (40), Phoenix81 (40)
  #71
Old 30th December 2020
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XLH 1200 S
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 83
Other Motorcycle Model: RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future
Originally Posted by 84rzv500r View Post
I'm not married to this idea yet...
Fender be polished aluminum but same bracket in black
Have to make a bracket to relocate the fender up... easy peasy...
I'll use this one on my XL1200S...
Also spent my morning tea time drilling bolts for safety wire...
I just bought some 2.5" x 0.065 wall 6061 tube... gonna have a go at making the brackets to relocate the fender and closing the gap outta alloy and polish it... remember i need 4 since i dont have my brake and bead roller here, would like to put a 1/4" flange on the edge to make it a bit stiffer, I'll have a go at making the bends in a soft jaw vice an shaping the radii on my belt sander, now where did i put my sharpie????
headpipes done and new stainless clamps on order....
1999 1200 Sport, SE 7500 ignition, SE air filter, DynoJet , Cone Engineering 2:1 pipe, Storz Steering damper, Russel Mach 3 Stainless Lines, VROD 4 piston front calipers, Bates Baja tires, XR1200 perf shocks, forks and triples coming very soon...
1983 XR-1000S to XR-1000RX Project Build Thread
ChinCactus's Avatar
ChinCactus ChinCactus is online now
She's coming together nicely!
Default wow found a box of parts I forgot about...
ok so i was cleaning up some more boxes in the shed and I came across a box a box labeled harley parts...
It was full-o-jems...
stock XR carbs, XR K&N Air Filters, OIL filters Brakes braided lines, new shiney axle tensioners... to much to list...
a set of NIB evo cams for XR heads from Mert...
and a set of NOS pegs/bracket for rearsets as described in the XR-1000 racing prep bulletin
Old 31st December 2020
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Need a hand cleaning out the rest of that shed??
ChinCactus's Avatar
THAT is one hell of a find!
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Sportster/Buell Year #2: 1981
Other Motorcycle Model: FXDC
Damn!
Steve
'03 1250 stage two thunderstorm heads, 536, mik 42
'01 Cyclone
'13 FXDC 96" stock
Old 1st January 2021
laying out my suspension choices... if I had more time I'd set this up in CAD but I will just mock it up in the bike... Measure twice cut a bunch...
even with the steeper XR1200 triples Im gonna have to raise the rear a bit more than the XR1200 shocks allow.. I have the forks up in the triples as much as they will go ... I have a chain tensioner and im not too worried about swing arm angle... I did this for my RZV500R and it saw 11 years on the race track... and I got it real close on the second try ...
I'm ditching as much sprung and unsprung weight as i can and still achieve the "look"
so I roughed out the new rear shock mounts... and mocked it up...
will trim a little more and sand to shape on the belt sander... I think this is nearly the last bit of fabrication before pulling the engine and refinishing the frame and swingarm...
the three holes in the bottom are so I can plug weld the bracket as well as weld it along the edges...
It a bit crude right now but it will be fine in the end...
oh and two more details... the rear of the fender needs to come down 3/16 to 1/4" and the rest of the old shock brackets needs to be trimmed off before i can weld the new ones on...
rejeanprimeau's Avatar
Can you show a picture of the face of the cams and number if possible?
PLEASE
Old 2nd January 2021
PLEASE
sure tomorrow.. i been out all day on the boat clearing an Island
