0 All balls generator
Last Post: jeffro57
0 Factory Chain Oiler
Last Post: tiderider
0 Gas Cap problem?
0 Top end tapping products
Last Post: RandallM
Last Post: slonez
0 Oil pressure sensor question. Is it no good?
0 1981 XLH Getting Recranked
0 Regulator contacts welding shut
0 New Top Fuel record
Last Post: owlsplace
0 VIeds advice...
0 XR caliper on Iron
Last Post: FuriousGeorg
0 DC Regulator wiring Accel 201102
Last Post: 72 Ironhead XLH
0 Clutch biting point
0 93 sportster when throttling up shuts off?
Last Post: Fivecats
Last Post: lehel
Last Post: Kzac
0 Only one breather bolt breathing?
0 ELectrical Issue 96 xl1200s
0 81 sporty 4 speed install ?s
Last Post: class of 82
0 Fork Gaiters
0 Clutch Spring plate poll
george (67), mwndragon (65), angusiw76 (46), XxValDeexX (41), ELPYRO (40), a175 (40), rolliphilip (31)
Old 19th January 2022
RandallM's Avatar
RandallM RandallM is offline
Other Motorcycle Model: Honda CM450
Other Motorcycle Year: 1982
RandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond repute
Default oil pressure sensor worth cleaning?
I have the oil filter off, and am tidying up the front area of the frame. I pulled the regulator/rectifier to clean all the sludge and crap off it and the wiring. While I am in there, is it a good idea or a bad idea to pull the oil pressure sensor to give it a cleaning? This bike has only 4500 miles on it, and the oil is pretty dirty, so I assume it sat in a garage for a long time. No idea when the oil was changed last time.
1995 XLH 883 Sportster Hugger
If it goes off after you fire up, then it's working.
Doesn't require maintenance.
Just make sure the wire isn't loose.
Old 20th January 2022
John Harper's Avatar
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
i would leave it alone. People have cracked their cases installing the oil pressure sensor and not realizing they have NPT threads, which are tapered. Too much tightening and you can cause a crack, depending on how your sender is mounted. As HS says, if it works, don't xxxxxx with it.
John
Originally Posted by john harper View Post
i would leave it alone. People have cracked their cases installing the oil pressure sensor and not realizing they have npt threads, which are tapered. Too much tightening and you can cause a crack, depending on how your sender is mounted. As hs says, if it works, don't xxxxxx with it.
John
+1
