0 Can I fill gas tank up to top?
0 Should I apolgise to Harley Davidson ?
0 That Stupid F@#$&in' Speedometer
Last Post: Conan
0 Check this one out for sale in the UK
0 Cutting out at WOT
0 V-Twin Solo Seat Plunger Kit
Last Post: fernf5
0 2012 883L mag to 16" spoke wheel
0 2021 HDs now Out!
Last Post: jimmyess333
0 Reflectors...Yeah, or Neh
Last Post: Marsikus
5 Tire Pressure?
0 Zippers Hammer 99 kit Info
0 Zippers 1250 kit
Last Post: seajay
0 New from France
0 New sportster in HD Research Survey
Last Post: Mr Dream Merchant
Last Post: phyhowe
0 1977 Shift shaft
0 Mid West Meet & Greet
Last Post: skien
0 83 XLH w/Velorex 562
Reynoldston (80), showmebandit (67), Hoppy1313 (67), FredrikK (65), Toejam503 (65), YO MUDA (62), Altopass (61), tim 2007xl1200c (54), w9awx (48), 3xtrastout (42)
  #31
Old 22nd November 2020
interesting i remember Kel Carruthers riding a 2 stroke Yamaha.didn't know about the Honda.
Old 23rd November 2020
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
He also raced Beneeli's and won the world championship on one of them.
Nobody in Australia could touch him on a race track.
He was actually faster than me.
Old 24th November 2020
Gold Member's Avatar
Sportster/Buell Year: 1972
Gold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud of
Originally Posted by needspeed View Post
Getting back to the original question, " if all 23 rollers are .0001" oversize will it be too tight?"
It's impossible to answer without knowing the exact ID of the race.
It's brand new. PS I don't have an inside micrometer. Should be stock size.
Stop by my build thread:
http://xlforum.net/forums/showthread.php?t=2076933
Four wheels move the body. Two wheels move the soul. Three wheels move the bowels.
Yes that's true.
I think Goldmember was asking if he could put slightly oversize rollers in without honing the race bigger. If he already had standard rollers at an unusually large running clearence then it's POSSIBLE he could and end up with an acceptable running fit without touching the race.
But we don't have all the facts. The size and condition of the race or if it's a new race and why he even needs new rollers. So he asked a question that can't be answered, yet.
My race was line lapped and is sized for standard rollers and my mainshaft is brand new.
My concern is because the first oversize is +.0004, so would .0001 over size at the outset be too much. We'll see I guess.
For all I know, having the rollers warm frorm being in the house and the crankcase cold from being out in the shed will matter.
My Chinese micrometer is likely a little wonky. The clutch needed a little grease so it would slip properly. I may give up trying to measure these rollers until I can pick up a Starrett mike. I've calibrated it a number of times and I'm not confident it's holding calibration. Would like a Starrett to compare it to.
Thanks for all who answered. I wasn't aware of just how sensitive measuring is to temperature. Will keep trying to understand this.
Blind Owl
There are correctives you can use if you keep your workshop at other than the 68 degree standard. So, for every 1 degree above you just subtract a tiny bit. (or add, depending)
But this presumes of course that the guy honing the race got it "Perfect" too.
I would probably just do a trial fitment. They will fit or they won't.
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: Cyclone
Other Motorcycle Model: FXDC
Just curious how do you calibrate it?
Steve
'03 Sportster NRHS 1250, Mik 42 HSR, SE 536, Dyna tech nosecone stage two lightning heads, supertrap 2/2
Old 25th November 2020
The directions that came with it say to close it all the way and set the 0. On youtube a guy sets the .0009 right on the line on the barrel. Well anyway it's a little fiddly to do and wanders easily. Would like a .5000 standard but haven't seen one yet.
Steve9's Avatar
Proper way is to measure a known object, usually a "gage block"
Zeroing out the micrometer is not calibrating the micrometer.
You are trying to measure "tenths" with an uncalibrated mic. And temperature just make sure you are in air conditioning, not warm garage.
Not trying to be a d#ck, you could bring it by a small machine shop. Someone would probably measure it for free
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Model #2: IronHead XLH
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
Yep, Steve, only way to calibrate at home...
Patrick
Flat Head Forever
You're not being a dick, I appreciate any and all tips and wisdom from the people who know what they're doing. It's the only way one can learn how to put one of these bikes together. You can't do it on your own without help.
