Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Tires, Wheels, and Brakes
5 1988 xlh1200//// dynatech2000i shorting/grounding help
0 fork tube cap
Last Post: Coz
0 Info needed on mini sumps.
0 Ironhead carbs
Last Post: spacecoast
0 Another Wrap Post
0 Graduated to Ironhead
0 Hammer 1250
0 Sticky Ironhead trans
Last Post: BigLerowski
0 Top end failure
Last Post: Mission1
0 Chinese S&S carbs
0 yost power tube guy
0 XL Forum T-Shirts ?
Last Post: Flying Monkey
0 HF bike lift
Last Post: Rgm883
0 No spark
Last Post: awright2009
0 Piston and cylinder condition
Last Post: duffy
0 Bikers choice main jet threads
0 Cleaning carbon build-up
0 Don't Think I Ever Did This
GWR (68), Helimad (66), dragon62 (58), metromix (58), Repohio (57), acenorm (52), reblu (44), jesterdoc (44), glucky7 (42)
Old 20th April 2019
BellaCorse BellaCorse is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 1983
Other Motorcycle Model: Triumphs galore
BellaCorse is an unknown quantity at this point
Default XB12R rear brake switch thread size?
I'm trying to help a friend with a 2005 Firebolt XB12R with a broken rear brake switch. I know it's a M10 single banjo bolt, but can someone confirm the thread pitch? 1.00 or 1.25? I need to order the part before I'll be able work on the bike to measure for myself.
Old 21st April 2019
I looked up a picture of the bolt -
https://st-paul-harley-davidson-buel...banjo-bolt-b1q
Then I measured the width of the threads on the picture - then compared that measurement to the number of threads...
Presuming the threads are 10mm - the threads # is 8 in that length = 1.25mm spacing...
