Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER & BUELL MOTORCYCLE RACING > Sportster & Buell Motorcycle Racing
Sportster & Buell Motorcycle Racing Talk about racing your Sportster motorcycle and/or Buell motorcycle.
0 HD Museum Video - 1968 IH Dragster by Tom Reiser
Last Post: thefrenchowl
0 old style fender skirted
Last Post: Proteus
Last Post: commando57
0 Turtle tank on '79 frame
Last Post: Ted Town
0 Ground Up Beginner Build
Last Post: Edster
0 Sportsterpedia Progress
0 What's your road name? How did you get it.
0 "S" model specific Q&A
Last Post: vagrant318
0 Coil polarity
0 Do you use a bike cover?
3 Two Trailer builds
5 Eye Protection When Riding?
0 New shocks on and old frame?
0 Pushrod o-rings gaskets question
the brewster (75), irate (74), jomosie (71), Gulfstream (63), LordVngr (60), [loopy] (48), aci2sux (46), doc05 (43), TOMSuperlow (41), Crusin_w00kie (40), DFuller1980 (40), h2oburymatt (38), Ivan Iler (36)
89", clearance, engine, frame, s&s
Old 27th July 2012
arizona's Avatar
arizona arizona is offline
Sportster/Buell Model: XLCR
Sportster/Buell Model #2: S&S 89"
arizona is an unknown quantity at this point
Default 89ci S&S Sporty engine into 1990 frame
Hello all,
Recently purchased a 1990 four speed Evo Sporty for the sole purpose of replacing its stock 883 engine with a complete 89ci S&S Hot setup kit .Which also includes the S&S Super Stock cases. On paper this S&S engine in .465" taller than stock. The 1990 bike in mind has .650"clearence !!!!!!!!(most bikes are lucky to have .250” clearance ) at the tightest location (aft rocker box/frame tube).Removed 883 stock engine and tried to install the S&S to no avail. Looks as if we need to remove at least .250" off of the top frame rail directly above the aft rocker box .What went wrong?? Is the 4 speed evo frame different than the 5 speed? Is the kickstand area different?? S&S claims their slightly taller engines should fit 1986-2003 Sporty frames.
Thanks in advance, BC
Old 27th July 2012
Dakin Engineering Dakin Engineering is offline
Sportster/Buell Year: 1987
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1991
Other Motorcycle Year: 1995
Dakin Engineering has disabled reputation
5 speed engines have the alternator up front right where the 4 speed kickstand mount is. I saw a Zipper's 100" in a modified frame. He shaved the underside of the backbone and welded in a flat plate above the rear head.
Sam
Old 27th July 2012
arizona's Avatar
Good point...noticed a bit of scratching on the underside of clutch cover where the kickstand area is as we manhandled the engine onto the 1990 frame.I would do the same with the welding option on the backbone but first want to ensure engine will drop fit into frame.So far its a no-go.
Old 27th July 2012
A 4 liter V8 eater's Avatar
Sportster/Buell Year #2: 1999
Originally Posted by arizona View Post
Hello all,
Please keep us updated on the build
Old 27th July 2012
arizona's Avatar
...before I start looking for a 1991 and newer solid mount 5 speed Sporty, you can bet I will do all that could be done to stuff that 89" into that 1990 4 speed frame.
Old 27th July 2012
norseXL's Avatar
norseXL norseXL is online now
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
It´s a pretty tight fit at the rear cylinder on the four-speeds so you may have to heat that area of the frame and get the big hammer out to fit aything higher.
Just my opinion though.
"In the design of an internal-combustion engine, as in all creative work of this nature, the æsthetic side must not be overlooked.
In the first place, beauty of form and of proportions is in it self an admirable guide to mechanical correctness;
for mankind has come to regard as beautiful that which is mechanically correct, whether it be in nature, in architecture, or in enginering."
Sir Harry R. Ricardo
Old 27th July 2012
arizona's Avatar
If thats all thats needed than I can comply...I have been also told a heavy duty hydro jack can come in handy with the heat to just tweek the frame tubbing.Eventually,think I just might remove the aft rocker box top cover and try and fit S&S motor just to see how all else falls in place.
Old 27th July 2012
norseXL's Avatar
Be shure, what ever you do, measure twice before starting banging to se if flattening will give you anough space.
Thankfully though, HD did not use any fancy steel alloy in those frames ( and the scale will tell) so some heat and force should not do any harm.
By heating just the area you are flattening, the rest of the frame should be OK.
Old 27th July 2012
arizona's Avatar
I have a good pulse on where the frame needs to be shaved and yes, will measure 30 times before and metal work begins...some folks even shave off some metal from the aft rocker box cover.BTW,here is Spain, a used Sporty (any year) costs at least 5k USD and I got a "deal" on this '90 for 3k Euros ($4k)
Old 27th July 2012
rontech rontech is offline
rontech is on a distinguished roadrontech is on a distinguished roadrontech is on a distinguished roadrontech is on a distinguished roadrontech is on a distinguished road
Is this an S&S sportster engine or a big twin EVO style? I didn't know S&S made a sporty engine. Should be interesting.
