Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
Last Post: bordens
0 Carb starting issue.
Last Post: Billy1200
0 Be Careful Out There!
0 clutch issue
0 Mikuni Knock Off "REVEALED" !!!
Last Post: davesz1r
0 Ebay ****evil knievel bike****
Last Post: MnKevin
0 Coil polarity
0 Chinese S&S carbs
Last Post: T. Clark
Last Post: bordens
0 80 xl1000 oil not circulating?
Last Post: smilinbrad
0 Wont Fire up!
Last Post: Mission1
0 XR mutt race bike progress
0 show me your sporty next to an old or rural post office
Last Post: Hellbent_4
0 1998 883 spits and sputters at around 3000 rpm
Last Post: denguy
0 old style fender skirted
Last Post: Proteus
0 Warm/hot kickstart
boblaine (85), mike wels (74), GaryR (64), cat5752 (53), Ocbuckeye (50), commandesc (45), vividblack05 (38), north_cack
Old 14th January 2014
islanddave islanddave is offline
Sportster/Buell Model: sportster 883
islanddave is an unknown quantity at this point
Default Decarbonizing Pistons
Hello,
Well this has turned into quite the project here. I have started numerous threads here. This one has to do with pistons. I was originally just going to replacing weeping base gaskets, by pulling the jugs but leaving the pistons in their respective bores. This way I would avoid having to re ring and hone. The pistons have alot of carbon on them. I also suspect it is oil build up due to the fact that it ran the stock air box for most of it's life. Is it possible to remove the heavy build up with the pistons still in the bore?
I'm guess yes but the best way would be to pull them. If I did this I would have to re ring and hone. I'm guessing in my area if I could find a reputable/competent place this would put me back about $300.........this is half way to a perfectly done 1250 kit.
Please advise.
Thanks Dave
A set of rings for those pistons is $43 for the pair from NRHS. You can get a nice ball hone quite cheaply on e-bay.
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
Shu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant future
Is this all being done to an 883? How many miles on it?
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
It is posted on the Buell page so I was assuming it is a 1200 Buell engine?
Yes 1200 Buell cyclone.......with about 28000 miles on it. Would I just buy a standard set of rings? How hard is it to ball hone cylinders? Yes I have a FWM on order. Believe it or not it was cheapest from my local Harley dealer. I just really can't believe how much build up are on the pistons.the front one in particular. No wonder I was getting pining this past summer...I mean the valve pockets have major deposits.
The cross hatch seems good, and there is minimal scuffing on the skirts, but the front piston and cylinder does have some vertical scratch marks at the front of the bore that my finger nail can catch on so maybe a rebore rather than a simple hone?
Thanks Dave
it all depends if you just want to get it running decent or do you want to do it right for long term?
Well I guess I now feel like how far down the rabbit hole do I want to go?
The tranny needs to be addressed slips out of 2nd gear temporarily...and the front connecting rod has shake in it but don't know how much is permissible? Haven't looked at the rear rod yet.
Doing it right and cheaply is not an option I know. It runs great I just wanted to address the tranny, and rear base gasket leak. If the base gasket didn't leak I wouldn't have torn into it. I think it started to leak because I rode it late into the season here when the temp was really cold, and blew the rear base gasket out due to the thickness of the engine oil at low temps at start up.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Thanks Dave
Dave, there's nothing about pulling the pistons from the bore that necessitates new rings. I wouldn't worry too much about that.
If you want to know if the cylinders/pistons/rings should be serviced, and whether they need an overbore or you can get away with a quick hone and new rings, the only way to know is to make the measurements. Anything else is just guessing. The service manual shows the bore dimensions and service wear limits.
Something you should probably do is read this thread I created several years ago: http://www.xlforum.net/vbportal/foru...ad.php?t=15735
It's an eye opener to measure factory cylinders sometimes. Measurements are the only way to know what's going on.
If you decide it needs an overbore, the measurements will also tell you how far you'll need to go to clean it up. You could do a service overbore with new oem pistons & rings for about $350 (assuming you can still get those pistons, I haven't checked lately). With forged pistons you're looking at closer to $500. Another option is a 1250 kit; we offer 1250 kits for your bike with premium ultra light and strong forged pistons, and strong, straight, round cylinders, for $540, see this thread: http://www.xlforum.net/vbportal/foru....php?t=1719215
Click Here to Contact Me
Jörgen Jörgen is offline
Bike Builder
Sportster/Buell Model: S&S XL124" streettracker
Jörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond repute
Dave
If you pull off the cylinders, carefully note how each piston ring is clocked. Otherwise I wouldnt recommend to put the top end together witout deglazing and new rings.
I would rebuild the top end, a lot of carbon is often caused by bad ring seal. Blow by pushes oil through the crank vent.
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
if your measurements are still in spec you don't have to remove the pistons from the bore to clean them,after you got it back together and the scoot is nice and hot....just spray(mist) of warm water into the intake(without the a/c) while ya got the revs in the 2k mark.
It will take carbon build up out of the engine make sure there is nottin behind the scoot or it will get covered with crap.
In three words I can sum up everything I've learned about life: it goes on.
