Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Engine Conversions
Last Post: bordens
0 Carb starting issue.
Last Post: Billy1200
0 Be Careful Out There!
0 clutch issue
0 Mikuni Knock Off "REVEALED" !!!
Last Post: davesz1r
0 Ebay ****evil knievel bike****
Last Post: MnKevin
0 Coil polarity
0 Chinese S&S carbs
Last Post: T. Clark
Last Post: bordens
0 80 xl1000 oil not circulating?
Last Post: smilinbrad
0 Wont Fire up!
Last Post: Mission1
0 XR mutt race bike progress
0 show me your sporty next to an old or rural post office
Last Post: Hellbent_4
0 1998 883 spits and sputters at around 3000 rpm
Last Post: denguy
0 old style fender skirted
Last Post: Proteus
boblaine (85), mike wels (74), GaryR (64), cat5752 (53), Ocbuckeye (50), commandesc (45), vividblack05 (38), north_cack
1250, buell, nrhs, ulysses, xb12x
Old 10th May 2015
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
For some reason it shows Zach's folder in the title bar, but it was my dyno and in my folder. We were previously comparing my dyno to Zach's stock '09, which was a stout 90 RWHP, but I didn't get a picture of that.
I think we have some more dynos coming up next weekend, and Zach loaned me an ECMspy cable, so I'm going to play with it a bit, raise my rev limiter, and see if I can add a little more fuel at cruising cadence, and re-dyno the bike soon. I should be able to get a few more HP with a higher limiter.
Love is the never-ending act of forgiveness - Peter Ustinov
Old 11th May 2015
PuddlePirate's Avatar
PuddlePirate PuddlePirate is offline
Sportster/Buell Model: 883 Hugger/Buell XB12
Sportster/Buell Model #2: Electra Glide
Sportster/Buell Year #2: 2002
PuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nice
Nice!! 100rwhp is nothing to sneeze at!
Your limits are self-imposed by what you let your mind believe
Old 11th May 2015
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Indeed...just ask Brad.
Old 11th May 2015
This engine is so smooth it is unbelievable. Absolutely no sputters at any rpms. It just keeps climbing in hp. With a better exhaust (this bike still has the stock exhaust!) and set the rev limiter a bit higher I think it would easily hit 105.
Old 13th May 2015
Phelan's Avatar
I hooked the actuator back up and reset the TPS. Without dynoing it again yet, it's hard to tell, but the race map doesn't feel nearly as much of a perfect fit as with the valve tied open, probably because the race map is for the race muffler, which doesn't have the valve. So once I get some dyno time on it to get a better idea of what it's doing, I'll play with the map to fine tune it to use with the valve active. Tuning with the active valve will give me a lot more midrange torque boost than I could ever see in power gains up top with a custom exhaust, so I will probably stick with the stock exhaust as it's pretty damn good. I will still raise the rev limiter though before my next dyno session, so I can see what the power peaks at, as up top is not different than before.
Old 14th May 2015
Any chance you guys in the shop could fab up a custom muffler for it?
Old 14th May 2015
Phelan's Avatar
I've thought about it, but it would take a lot of R&D to get it sorted. I may try it in the future though, using a stock muffler as a core, to get a functional valve.
Old 29th May 2015
Phelan's Avatar
Big Ugly is going bigger! I just ordered new springs, lifters, shorter pushrods, and 1.900" intake valves. Gonna go bigger in the intakes and deck the heads a bit more, since my compression isn't as high as I'd like. Will eventually dyno with both stock and race muffler. It may cost some bottom end, but I'm going to tie the valve open again for ease in tuning. The race map just isn't a great fit for the stock muffler, at least not with the other mods I have. I'm also going to keep playing with ECMspy until I can get the higher rev limiter to stick; it didn't the last time I tried, but I may have switched maps by accident at the time.
Old 30th May 2015
What's the end goal?
Old 31st May 2015
Ranchero50's Avatar
Ranchero50 Ranchero50 is offline
Sportster/Buell Model: 1200 Street Brawler
Ranchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond repute
I don't think the custom muffler would be as difficult as you figure. I modified a can muffler that was on my neighbor's '91 ninja. It was a perforated core with fiberglass wrapping. I cut the front half of the core into segment and made a plate and washer set up for it that kept the area of the perf pipes holes the same as the inlet pipe. The back section got a loose layer of glass reinstalled. His was a slip fit with an aluminum shell and he said it performs at least as good as before and now sounded a lot like a Ferrari.
The build thread... http://xlforum.net/forums/showthread.php?t=1821880
