Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
12 Crankcase breathing?
0 Do you use a bike cover?
Last Post: Old Rocker
0 Rear sets?
Last Post: bordens
Last Post: Vic8028
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 "S" model specific Q&A
0 Ground Up Beginner Build
Last Post: Paul.W
0 Turbo Iron 883
Last Post: Cj_
Last Post: Blackmagellan
0 Clutch springs
Last Post: BigMek
0 Coil polarity
Last Post: Bikeaholic
0 Info needed on mini sumps.
0 primary cover
Last Post: smoggy
Last Post: davesz1r
0 Chinese S&S carbs
0 oil transfer valve
0 Tappet blocks and tappets
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
Old 17th October 2016
dsmithjr_1960 dsmithjr_1960 is offline
Sportster/Buell Model: Buell Thunderbolt
Other Motorcycle Model: Harley Ultra Classic PE
Other Motorcycle Year: 2007
dsmithjr_1960 is an unknown quantity at this point
Default 98 thunderbolt Rockers leaking
Hi i bought a blown up thunderbolt to get familiar with the Sporty engine I rebuilt it and it moves pretty good. However I have a constant leak from the Rockers both upper and mid, I have tried everything except a silicone bead around the surfaces. I replaced gasket 3 times last one I super glued it as I was told from a few people? Question I am now thinking is the heads may not be venting? not sure the year of the heads a buddy bought for me but did have to change the front mount bolt from 7/16 to 3/8? They looked the same but anyone know how to figure out if the head are just not venting?
Old 6th December 2016
rejeanprimeau's Avatar
Buell vent by the cover, your's by the two umbrella, one on each head, the side over the carb?
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
If you have 4-speed heads (86-90) then you are correct, those have no facility for a breather and therefore if installed on a 5-speed (91+), you'd have a sealed motor that would soon be leaking past gaskets. You'd also have pushrod rub issues, because the pushrod angles are different and the holes where the pushrods pass through the heads are in a different place.
Easy to tell. Are the two carb mount/breather bolts 1/2-13 thread, with hollow breather bolts? Or are they little 5/16-18 bolts?
Click Here to Contact Me
