0 Recent 1275 Dyno Tune
Last Post: davesz1r
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: 4th of July
0 theNeckerCube's Problems (Exhaust, Carb, … ?)
0 Mid Glide width?
0 Can’t go over 70mph
0 Oh these college kids
0 Parts
0 ooops
Last Post: roadmut
0 Rubber mount gas tank part
0 ultima install without VOES
0 Now running 3.40 factory gearing
Last Post: cliffm
0 Yearly Allotment of Miles
Last Post: Bigshankhank
0 Headwork
Last Post: ericfreeman
mbsales (73), loopback (61), HHahn001 (51), NHXJer (46)
castings, cylinder, heads
Old 5th September 2018
ChivaKnievel ChivaKnievel is offline
Sportster/Buell Year: 1973
ChivaKnievel is an unknown quantity at this point
Default Early Heads + Cylinder Castings
Hey there, I've been lurking the forum ever since I got my first Ironhead however long ago and first would just like to thank everyone here for all the invaluable information I've found over the years.
Onto the topic at hand, I just picked up a big lot of Ironhead top end stuff and am currently going through the (slow) process of cataloguing it all.
Most of it has been pretty straightforward, but even after searching through every sticky thread here and elsewhere as well as the sporsterpedia page I'm still left with a couple unresolved questions.
First is this rear cylinder, which based on the tag would of course date to October 15, 1966.
The large rounded triangle next to the month designation I cannot find any information on however. Does this have any significance? Or is it just some oddity from the casting company these were outsourced to?
My second question is about a pair of 900c heads. Of the other examples I have the rest have the same protruding boss for the rear set of head bolts seen in the first picture. One pair however has a much shorter, almost flush boss as you can see in the second picture. Does this correspond to a certain year range? (All of the heads have the standard 16683-57 casting no.)
Thanks in advance for your help, and if I run into any other peculiarities I'll be sure to share some pictures.
yoshi's Avatar
yoshi yoshi is offline
Sportster/Buell Year: 1971
Sportster/Buell Model #2: FXRS-SP
Sportster/Buell Year #2: 1985
yoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud of
In the two cylinder head pics it is the spark plug area that differentiates them. From the pic it looks like the second head has a raised boss for the spark plug which I think would make it an XLR or iron XR head.
8ball's Avatar
8ball 8ball is offline
Bike Builder
Sportster/Buell Model #2: xlch stroker
8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of
you might want to chat up the guys on the k model site about the cylinder. they deal with up to 1969 and have documted some of the smallest details you can imagine.
as yoshi said the 2nd head pic looks like an xlr head ( totally useless ill gladly take it off your hands ) id bet the bolt surface is just a variation in the casting but just for the sake of knowledge ill see if my xlr set is like that this weekend. i think one of dr dicks sets is on the shelf next to mine if it is thatll give 3 sets to compair.
"ya...i saw a guy do this once... " -DR DICK
Chuckthebeatertruck's Avatar
Sportster/Buell Model: Xlh
Sportster/Buell Year: 1959
Sportster/Buell Year #2: 1969
Other Motorcycle Year: 1969
The "rounded triangle" is the forge's casting mark. Yours is just very rubbed out, usually they are sharper. You'll find that casting mark on most hd cylinders from the 30s to the 70s.
I'm not sure on the heads.
As 8 Ball notes, much of the deep knowledge that had been here has moved to the k model site. It's more of a nut and bolt resto forum, but it seems that is what you are trying to figure out.
Just keep in mind you can still buy brand new, quality repo cylinders for $50 set from BMI karts until they finally run out of sets. In fact, I think I'll go buy another set right now ;-)
Thanks for the info guys, I'm not sure how the spark plug boss wasn't more obvious to me than the head bolts, haha. I couldn't find any other good shots of XLR heads online to compare to other than an old Hunting Harleys video where he happened to mention them, so I thought'd I'd upload some shots of these for everyone else to reference.
I suppose from here I'll give these things an electrolysis bath and see if I want to have them rebuilt.
you should have looked on the forum here.these are mine IMG_0056 by Bruce Stoudt, on Flickr the bolt holes have been relocated for 1000 c.c. cylinders,so that won't match yours.
8ball's Avatar
Bike Builder
chiva- yours were also drilled for external oil drains
im tellin ya total junk send em here, ill throw em in the lake for ya
Old 6th September 2018
Oh wow, those look nice. I've got a 73' I'm buttoning up for my brother, maybe I'll end up doing something like this...
Huh, I was wondering what those "repairs" were. These things just keep on getting more and more interesting.
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
The rounded triangle is from the MOCASCO foundry, in Milwaukee... Normally has a intertwined "MC" inside it...
see here:
https://www.jockeyjournal.com/forum/...ad.php?t=91759
Patrick
Flat Head Forever
Chiva,all the machine and port work was done by forum member mrmom9r.here's a link to part #2 of my thread http://xlforum.net/forums/showthread.php?t=2069695
