0 Tire pressure
Last Post: mvent
Last Post: fafcpa
0 Chinese S&S carbs
0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
0 Gasket placement
Last Post: Billy1200
0 Top end failure
Last Post: Mission1
0 What a birthday I've had
0 Mystery transmission piece??
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 XR mutt race bike progress
Last Post: supermotolew
0 Info needed on mini sumps.
Last Post: mrmom9r
0 Don't Think I Ever Did This
Last Post: Veeflys
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sticky Ironhead trans
0 Inherited Ironhead
0 HF bike lift
Last Post: BigLerowski
0 Graduated to Ironhead
Old 31st October 2019
Mjolnir's Avatar
Mjolnir Mjolnir is offline
Sportster/Buell Model: XL 1250
Mjolnir is an unknown quantity at this point
Default Compression and oil pump
Hi,
I have an "06 Sportster with a 1250 conversion along with gas flowed heads and larger intake valves. I replaced the standard oil pump with an Ultima High Volume Oil Pump p/nr 98 675. Could not find any reviews on line and was wondering if someone else installed it and what their opinion of it is?
I also had a compression test done and the tech report 10 bar (145 psi) on the front and 11 bar (159,5) on the rear. Is this within spec for a 1250?
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Originally Posted by Mjolnir View Post
Hi,
First off, the actual psi on a compression test depends on the gauge among other things like cams. That said, a 15psi difference is borderline significant imo.
I'd be doing a leak down test.
Old 1st November 2019
Mjolnir's Avatar
Thanks Gunner, appreciated
60Gunner's Avatar
Chief of Security
A compression tester that doesn't have a schrader valve in the end of the hose that screws in the heads is going to read low. Mine read 165 on a 1250 but it read 165 on both. When I checked it with a better tester with the schrader valve in the proper location they both read 210.
The fact yours is 15psi different is the issue. Not a huge difference but enough to indicate a problem on that front cylinder. A leakdown test will tell you where.
You can also try squirting a little oil in that front cylinder and test it again. If it comes up, that indicates rings.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Make sure the throttle was held wide open during the test, and the opposite spark plug was removed.
Click Here to Contact Me
Bored now Bored now is offline
Sportster/Buell Model: 883
Bored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond repute
If you still have the stock CV carb you need to lift the slide in the carb as well.
