0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Chinese S&S carbs
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
0 Gasket placement
Last Post: Billy1200
0 Top end failure
Last Post: Mission1
0 What a birthday I've had
0 Mystery transmission piece??
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 XR mutt race bike progress
Last Post: supermotolew
0 Info needed on mini sumps.
Last Post: mrmom9r
0 Don't Think I Ever Did This
Last Post: Veeflys
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sticky Ironhead trans
0 Inherited Ironhead
0 HF bike lift
Last Post: BigLerowski
0 Graduated to Ironhead
0 Cutting Out Cracking Popping, Etc, After Fully Warmed Up
Last Post: jharback
Old 26th December 2019
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud of
Default Uh oh!!! Brass flakes/dust (a lot of it too) in my oil
I am 246 miles into the break-in period on my 2019 Iron which has a 1250 conversion. I decided to change the oil today and boy, was I confronted with a big surprise! When I removed the oil filter, I discovered a whole lot of brass flakes/dust inside. I had experienced something similar to this on my sport bike before, but those flakes were copper in color. That turned out to be a #3 rod bearing failure. I don't have a good feeling at all about what I am seeing here though. I am hoping like heck that someone tells me that this is normal and a result of the oil pump gear meshing with the new bronze oil pump drive gear that I installed on the crank during the build. If not, then I know what has to be done.
PS. I took pics of what I am referencing above, but don't want to fool with setting up an account with an image hosting site. However, if someone would like to PM me their email address, I will email them the pics to be posted in this thread.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
I'll send you my email if it's not already listed.
I'm assuming you lubed everything up good with assembly lube on install?
Yes, I was very generous with the assembly lube.
60Gunner's Avatar
Chief of Security
Nibelungen's Avatar
Sportster/Buell Model: xl883n Iron (2019 engine)
you had torqued properly the bronze oil pump drive gear...?
according to Hammer site it has to be overtorqued to be in the safe side..
on the 90" inches conv of Sportytrace it came loose for that reason if i remember well
on the lion's corpse celebrate the dogs... still the dogs are dogs and the lion a lion...
60Gunner's Avatar
Chief of Security
Yeah I forget what I torqued mine to but it was was more than stock. Used red loctite too.
Are you sure they're brass? Oil can make them look like brass. Try a magnet? That IS alot. I could see fine metal specs in mine but not like that.
Cam bushing(s)? Did you clearance everything? Leave a wrench in there? ;p
I'd be pulling the cam cover.
Yes, I bought the Hammer locking tool and torqued it to 80 ft-lbs per Dan’s instructions.
It looks yellow like brass to me. When I experienced something similar on my sport bike, the flakes were copper in color and it was a spun bearing. I didn’t leave any tools in the cam chest. I wouldn’t call myself an expert engine builder, but to date, I have built two 2015 twin cam motors, one 2019 Sportster and one 2008 GSXR-1000. I have also installed cams in two Milwaukee 8s.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Please contact me.
Click Here to Contact Me
Nibelungen's Avatar
i'm sorry for you.... but you know you had to pull your cam cover... maybe it's not too late...
