0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Chinese S&S carbs
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
0 Gasket placement
Last Post: Billy1200
0 Top end failure
Last Post: Mission1
0 What a birthday I've had
0 Mystery transmission piece??
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 XR mutt race bike progress
Last Post: supermotolew
0 Info needed on mini sumps.
Last Post: mrmom9r
0 Don't Think I Ever Did This
Last Post: Veeflys
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sticky Ironhead trans
0 Inherited Ironhead
0 HF bike lift
Last Post: BigLerowski
0 Graduated to Ironhead
0 Cutting Out Cracking Popping, Etc, After Fully Warmed Up
Last Post: jharback
Old 12th February 2020
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Be sure to protect the end of pinion shaft when using that one.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Yeah I covered it with a rag. Mine just needed a little nudge with a similar puller. I just steadied the puller with one hand and turned it with the other. Didn't take much at all.
Bryan1976's Avatar
Bryan1976 Bryan1976 is offline
Sportster/Buell Model: 1275 Sportster
Other Motorcycle Model: Dyna Wide Glide
Other Motorcycle Year: 1998
Bryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond repute
As the guys said make sure you protect the gear. If it slips just a little bit you are prone to breaking teeth off.
Blue collar knuckle buster. Some call me slow Stroh. The people I work with call me G.S.D.S. They say if you want it done right , you better send G.S.D.S
Old 17th February 2020
wrkdWS6's Avatar
wrkdWS6 wrkdWS6 is offline
Sportster/Buell Model #2: XLH1000
Sportster/Buell Year #2: 1979
wrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond repute
Thanks again fellas. Heated the absolute bejesus outta the gear to melt/flake off the remaining red threadlocker. Then rented a 2-jaw power steering puller from Advance Auto which made easy work of removing the gear. Zip-tied the 2 jaws together to hold it on there good, thanks to Sportsterpedia for the tip. My original issue is that I just didn't heat it up good enough to melt all that threadlocker off.
Reminder to replace your oil pump drive gear with a bronze Buell one when in there. I did not when I stuffed in some cams about 5 years ago. Well it's showing some bad wear so I am glad to have it outta there now. Don't skimp on it like I originally did, failure could ensue and it seems like I got lucky this time around.
'06 1200C - 1275, chain & '79 XLH - rigid, kicker, fancy paint, hopped up, 200 rear
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Yep, that's a good thing to do. I put in the bronze gear with my cam install. I'm going to change cams again so I'll get to see how it looks. And check to make sure there's no extra bronze / brass debris under the cover.
