0 Tire pressure
Last Post: mvent
Last Post: fafcpa
0 Chinese S&S carbs
0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
0 Gasket placement
Last Post: Billy1200
0 Top end failure
Last Post: Mission1
0 What a birthday I've had
0 Mystery transmission piece??
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 XR mutt race bike progress
Last Post: supermotolew
0 Info needed on mini sumps.
Last Post: mrmom9r
0 Don't Think I Ever Did This
Last Post: Veeflys
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sticky Ironhead trans
0 Inherited Ironhead
0 HF bike lift
Last Post: BigLerowski
0 Graduated to Ironhead
Old 21st May 2020
Yeah, I’ve gone heavier on all of mine. Even tried some service entrance cable but the weight slowed the bike too much!
Old 21st May 2020
spoon spoon is offline
Other Motorcycle Model: KLR 650
Other Motorcycle Year: 1987
spoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant future
Just an interesting thing on corrosion inside a wire. I worked in a facility that had an electrical fire in one section.Wires were run in a chase way that was also used to move air. The air in the chase way had corrosive gasses in it and this was known. The wiring was in a protective enclosure, or so was thought. Corrosion caused high resistance and a fire. The post fire investigation showed corrosion 2 feet up the wire under the insulation. A sister facility had just installed a similar system with modern terminations and that was inspected. Guess what, corrosion! After about 4 months of being put into service a redesign had to be done. A very expensive lesson for not paying attention to detail. A connection that is subject to corrosive liquids/gasses has to be incapsulated. And yes I know easer said than done. But we can inspect.
Old 21st May 2020
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: Cyclone
Other Motorcycle Model: FXDC
You cain't never see the condition of the wires inside the insulation.
Mech installed a new starter in my duramax couple years ago suggested I have the ground lead replaced. dual battery setup I said heck yes. Grounds are the root of many syptoms
Old age-I actually listen sometimes now
Steve
'03 Sportster NRHS 1250, Mik 42 HSR, SE 536, Dyna tech nosecone stage two lightning heads, supertramp 2/2
Old 21st May 2020
ReddTigger's Avatar
Those Duramax's benefit greatly from installing additional ground wires much bigger then stock..
do a google search gm big 3 upgrade.
States I've Ridden in
71.3 hp 70.8 tq
