0 Tire pressure
0 Chinese S&S carbs
Last Post: sleighcrane
0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
0 Gasket placement
Last Post: Billy1200
0 Top end failure
Last Post: Mission1
0 What a birthday I've had
0 Mystery transmission piece??
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 XR mutt race bike progress
Last Post: supermotolew
0 Info needed on mini sumps.
Last Post: mrmom9r
0 Don't Think I Ever Did This
Last Post: Veeflys
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sticky Ironhead trans
0 Inherited Ironhead
0 HF bike lift
Last Post: BigLerowski
0 Graduated to Ironhead
Old 29th August 2006
Gone Gone is offline
Default #2 cam drive gear
The andrews cams website talks about changing the #2 cam DRIVE GEAR on my 05 883, its pressed on, when it this necessary?
Shamdog's Avatar
Shamdog Shamdog is offline
Sportster/Buell Model #2: Dyna Low Rider
Sportster/Buell Year #2: 2004
Shamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished road
In 2000, HD changed the pitch of the pinion gear that drives the oil pump. Cams are the same, so if you buy used cams (or the wrong new ones) you'll have to have the pinion gear swapped out. That's what's pressed on. I think it's more trouble than it's worth so just get the right gcams to start with.
'00 1200 VC (Very Custom)
Daytona Ignition / SE Round AC / HSR 42 / NRHS Stage 2 XB Heads / Hurricane 10.5:1 pistons / SE .536 Cams / RB LSR 2-1 / Ghost Flames / Bling and...well, you get the picture
Old 24th September 2006
LDO's Avatar
LDO LDO is offline
Sportster/Buell Model: 2005 XL 1200 Custom
Other Motorcycle Model: BD MASTIFF
LDO is on a distinguished roadLDO is on a distinguished roadLDO is on a distinguished roadLDO is on a distinguished roadLDO is on a distinguished road
Great post Turbo. Did you put stockers back in or did you upgrade?
LDO
2005 1200 XLC (Budget Thugged Out)
S&S A/C
V&H Short/Shot/Staggered
"Damn it feels good to be a THUGSTA!!"
Turbota's Avatar
Turbota Turbota is offline
I removed the SE .551" cams and installed a set of Zippers Red Shift cams (see signature). They take your quiet stock cams, then grind off the lobes and then weld on new lobes .... Sounds kinda screwy, but if your stock cams were quiet, the new cams will be too.
04 XL 1222R
LDO's Avatar
LDO LDO is offline
Wow,
thing must run like a beast! I may have to contact you when I decide to start upgrading my motor for serious power.
Old 25th November 2006
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
I would Assume we are talkimg about the "Bolt in" Cams here, correct ??
Old 6th December 2006
davidcar's Avatar
davidcar davidcar is offline
davidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura about
Great info! Just would like to add a tip. I used a tool (looks a like a screw driver with a magnet on the end) to hold the lifters up while installing the new cams.
1200 XLH, "D" shaped exhaust port, SE 497 cams, 9.5:1 CR, 1.850 inlet & 1.615 exhaust valve, 48 primary & 190 main jet, NOKK needle no shim. 84TQ & 81HP
Old 20th January 2007
kariglam1's Avatar
kariglam1 kariglam1 is offline
kariglam1 is a jewel in the roughkariglam1 is a jewel in the roughkariglam1 is a jewel in the roughkariglam1 is a jewel in the roughkariglam1 is a jewel in the roughkariglam1 is a jewel in the roughkariglam1 is a jewel in the roughkariglam1 is a jewel in the roughkariglam1 is a jewel in the roughkariglam1 is a jewel in the roughkariglam1 is a jewel in the rough
Hello all I'm about to install Andrews N3's into my '05 1200 custom and was wondering why you would put the bike into 5th gear only reason why I'm asking is i haven't read it in the manual or the instructions that came with the cams i know the manual is more about rebuilding the engine but i would think the instructions would say something about that any way if someone could let me know i would appreciate it thank you in advanced.
Turbota's Avatar
I posted to put it in 5th gear so it would be easy to rotate the engine by moving the bike back and forth ... remember, you want the lifters on the cylinder you are working on in there full down position when installing the rocker box on that cylinder.
kariglam1's Avatar
Thank you i figured it had to do with that. Thanks for all the great info on this site I've learned alot and I know I will continue to do so.
