0 Performance gains from TC88A ?
Last Post: kkbii
0 One More Ohio Meet & Eat?
Last Post: kkbii
0 The SPORTSTER car?
Last Post: lostNdallas
0 Halloween 1250 Conversion
0 Do you Run a Fuel Filter?
Last Post: ZCarFan
0 Hello from LA area
0 Hello everyone
0 Hi everyone
5 Which backrest gives more space for passenger?
0 Hello from Holland
0 Ran out of gas.
Last Post: Marsikus
0 Round Air Cleaner Poll
0 1969 Shifter shaft bushing
Last Post: Doc308
0 add oil and ride
0 Brakes?
Last Post: Dariusz
5 about the 1999 Sportster Right Fork converting to dual brakes
3 Ironhead Pictures Thread
0 Gear Spacing Question
0 WTS: Forward Controls 2004-13
Last Post: XL1275
Old 30th August 2019
Samson4651$ Samson4651$ is offline
Samson4651$ is an unknown quantity at this point
Default Engine knock
2001 Sportster Hammer 1250 kit with impact head service and Andrews N4 cams, Dyntek ignition. started with 1250 kit added cams and impact head work a couple years latter. had an issue with the wrong cam cover gasket which fit but wrong year started the bike tried to run a little thinking new start up oil needed to circulate. stop bike Hammer called the next day said they sent wrong gasket. I replaced and since engine knocking, don't believe its rod knock no up-down a little side to side. any suggestions Thanks, any way to upload a video/sound clip?
Have you been in touch with Hammer? They are excellent technicians and are very helpful...
Folkie Folkie is offline
Hi Samson4651$, welcome to the Forum.
You started your thread in the 'Forum FAQ / How To' section, which is for posts about the Forum, and how to use the forum functions, so I've moved it to the 'Sportster General Discussion and Problems ' section.
...I replaced and since engine knocking, don't believe its rod knock no up-down a little side to side. any suggestions?...
Your lifters are suspect if the "wrong" gasket kept them from getting oil.
Air-cooled Forever
Did you relube the cams, etc. with a lubriplate or something when you replaced the gasket?
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
Did you relieve pressure on the cams when you removed the cam cover?
rejeanprimeau's Avatar
How loud the knock, if very loud, check cams placement, if only a tick, your rocker shafts. They are simple engine.
Old 31st August 2019
Sportster/Buell Year: 1991
If you have the wrong cover gasket, one of the oil galleries could have been blocked, starving whatever it feeds of oil. Not good.
John
Old 3rd September 2019
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Year: 1974
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant future
A mechanics stethoscope are cheap and will help you pin where the knock is coming from.
Murphy's Law :vvet:
