0 .551 Cams in an EFI 1200
0 1993 XLH883 Ignition switch Wiring
0 Multiple timing marks?
0 SBS Project - Sportster Chop w/ Lots of Photo's
0 Handlebars
0 Riding in the rain
0 diagnose noise in engine after rebuild
Last Post: seajay
0 Removing countershaft from access cover
Last Post: Russ
0 Best Battery Maintainer and/or Booster?
0 Anti reversion “muffler”
Last Post: JaKaL
Last Post: a-sad-anorak
0 question about new trans door
0 Where were the IronHead sportsters Made.
0 BMW reverse trike build
vlmuke, wazza (48), Grizzwold (44), roaldtm (39), redtacoma31 (34)
  #31
Old 8th June 2006
chrishajer's Avatar
chrishajer chrishajer is offline
Sportster/Buell Model: Dead Hugger
Sportster/Buell Year: 1988
chrishajer is just really nicechrishajer is just really nicechrishajer is just really nicechrishajer is just really nicechrishajer is just really nicechrishajer is just really nicechrishajer is just really nicechrishajer is just really nicechrishajer is just really nicechrishajer is just really nicechrishajer is just really nice
1 MILLION ft lbs! Wow
Ummm....
The socket will not fit into the bottom of the fork leg. You need a long allen key (which is the really hard way to do it) or a special 6mm long allen socket. I have one from Snap-On like this:
http://buy1.snapon.com/catalog/item....store&tool=all
You're right, with the caps off and springs out, the damper tube will spin when you try to remove the bolt from the bottom. You can do it with a 3/8" air impact without reinstalling the springs, but if you have no compressor, you're better off installing the springs, which will put enough pressure downward to hold the damper tube from spinning (usually.)
The quickest way and easiest is the 3/8" air impact. Maybe there's a shop nearby that could zip the bolts off for you?
I still can't find the tool I am remembering that you can insert from the top and hold the damper tube. Race Tech's website is down for the tool page. I think they had one.
HTH
--Chris
Old 8th June 2006
chrishajer's Avatar
I must take too long to write my posts - xena beat me to it
Air tools would be the preferred method. xena, you got lucky with yours coming out.
Be careful too not to strip the head of that bolt. You'll be drilling the head off it if that happens. Not fun.
--Chris
Old 8th June 2006
release's Avatar
release release is offline
release is an unknown quantity at this point
Well, my tubes are in my garage, and my compressor is at a place I'm doing some wood working. I guess I'll try, in this order:
1> to use one of the wrenches I bought today, without putting the springs back in
2> To use one of the wrenches I bought today, after putting the springs in
3> To take the tubes down to where I'm working, and try using the impact wrench - but I'll still need a long reach hex drive socket, won't I?
John
We all need a Release today!
Old 8th June 2006
chrishajer's Avatar
I think #3 is going to be most successful, not that you shouldn't try the others.
Yes, you will need that long 6mm allen socket. You can also take an allen key, cut off the bent part so you have just straight, then jam that into a 6 point, 6mm, 3/8" drive socket, to make your own "special tool." That would be fine.
Just be careful not to strip the head of the bolt. I mean, don't use the cut end of the allen in the head of the bolt - it WILL slip out.
Good luck!
--Chris
Old 8th June 2006
release's Avatar
All right I'll try 1 (if it works everything's golden and I save a trip) then 3, because I dont want to have to wrestle with the fork caps more than once if I don't have to.
Thanks Chris and Xena et al for your help.
John
Old 8th June 2006
chrishajer's Avatar
Yeah, the fork caps are a PITA to reinstall.
--Chris
Old 8th June 2006
xena's Avatar
xena xena is offline
Assistant Administrator
Sportster/Buell Model: 1212 conversion/497 cams
No luck involved chris, again, I followed the directions
which iirc, told me to keep the springs in the fork tubes in
order to keep pressure on the damper tube.
John, yes, even using air you'll need the long socket in
order to get it in there...good luck and I'm sure once you
finish it up you'll agree with me that it's not that bad a
job and you are going to LOVE the difference.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Old 8th June 2006
chrishajer's Avatar
xena: the Harley gods were smiling on you when you did that job.
In the shop, using air, with the proper allen, springs still installed, cap on, they are a BITCH to get out on some bikes with a 3/8" OR 1/2" impact sometimes. I have to say there's luck involved. Maybe it has something to do with the age of the bike when you go to do the work. Yours would have been pretty new. I'm glad it went smoothly for you.
--Chris
Old 16th January 2007
SavageRider's Avatar
SavageRider SavageRider is offline
Sportster/Buell Model: XL883C
SavageRider has disabled reputation
Thumbs up
Originally Posted by chrishajer View Post
Here's an annotated version of the same pic. Pic is from Race Tech, notes are from me.
You are going to add the Progressive top out spring (the little one) right between the top damper tube, and the bottom of fork tube, right where the top out spring is now.
--Chris
Thanks Chris this cleared up a few questions I had too.
The impossible is something you haven't made happen yet.
