Last Post: Andy56
0 MS rollers way too tight
Last Post: Rolli
Last Post: PappaBravo
0 Newbie
Last Post: BitterOldMan
0 KBS tank sealer
Last Post: jcro61
0 OEM Headlight Bucket?
Last Post: Mission1
0 Tools
Last Post: 84rzv500r
0 my sunday driver...
0 -65A mufflers
0 my daily driver
Last Post: webman94
0 Now running 3.40 factory gearing
0 carbs?
0 Better Brakes
0 just for my head
Last Post: Iron Chuck
0 2020 End of Year Report
0 81 parts
Last Post: kobra50
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: exexpat93
0 Grateful Dead Timing Cover Source?
Last Post: rocketnorton
0 Brake light issues
Last Post: 45Brit
Old 17th November 2012
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Great article. Rep to you when it lets me.
Folkie
South East England Riders
dashadow's Avatar
dashadow dashadow is offline
Sportster/Buell Model: 883C
dashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant future
Good write up, but dang, that's a complicated mechanism for just a filler cap.
I'm not into this Twitter thing, I prefer to follow people in person.
Old 18th November 2012
oreocat1's Avatar
oreocat1 oreocat1 is offline
Sportster/Buell Year: 11
Other Motorcycle Model: Yamaha FZ-07
Other Motorcycle Year: 2016
oreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond repute
Good Job, Good to know.
Old 5th January 2013
mr.coffee's Avatar
mr.coffee mr.coffee is offline
Sportster/Buell Model: XL883N
mr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to behold
Yay!!! I just fixed mine. I gutted it, and put it back together with no springs. That allowed me to line it up easier, since the basket was pretty badly warped.
I drilled off to the side, along the lug as suggested, and used a small allen set screw - I already had the drill, tap and screws from making dice into knobs for guitars.
When I put it all back together, I noticed that the screwed down side stayed put, but the other edge was still creeping up. I grabbed it in some ChannelLocks and screwed it down along the lug as well.
Total time, maybe twenty minutes.
Awesome!
-m
Gamble Gold's Avatar
Gamble Gold Gamble Gold is offline
Sportster/Buell Model: Iron
Gamble Gold is just really niceGamble Gold is just really niceGamble Gold is just really niceGamble Gold is just really niceGamble Gold is just really niceGamble Gold is just really niceGamble Gold is just really niceGamble Gold is just really niceGamble Gold is just really niceGamble Gold is just really niceGamble Gold is just really nice
Looks like useful info.
Old 22nd January 2013
domi88ss domi88ss is offline
domi88ss is an unknown quantity at this point
Nice fix, thanks,
For my part, i've got another problem : I can't screm my cap completely in position and when I pop it down, it doesn't fit flush with the tank top. I tried with another cap, try to turn it 180 degrees before... doesn't work. I saw others 04 + with the same problem. Is there anyone who have a clue?
Folkie's Avatar
Brass Nut
Originally Posted by domi88ss View Post
Nice fix, thanks,
Could it be this:
Originally Posted by JohnK View Post
One of the first symptoms is that the cap will not stay flush, but will protrude maybe an eighth of an inch above the tank surface.
JohnK's Avatar
JohnK JohnK is offline
Sportster/Buell Model: Dearly Departed XL1200C
Other Motorcycle Year: 2000
JohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant future
Nice fix, thanks,
You just need to turn the cap a few more degrees. The last bit can be really tough. It helps if you wear some gloves. The big O-ring loses some resilience with age and heat. I fixed that with a real light coat of silicone grease on the O-ring... work it between the inside surface too. Also check the O-ring seat inside the filler neck, it may have a layer of coked oil and grit, carefully clean that off with a dab of solvent and a rag, the goal is to make this as slippery as possible. Make it a habit to check your oil on a regular basis, this seems to help keep the O-ring pliable... maybe it's my imagination, but it works for me, and I haven't had this issue for well over a year now.
John from Windsor Ontario
'00 FXDL
NI-STR's Avatar
NI-STR NI-STR is offline
Sportster/Buell Model #2: Nightster
NI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to behold
Great write up John. Thanks. I'll know exactly what the problem is when mine decides to give up.
(still ok for now)
Hey, John, aren't "Sporty's" a lot easier to work on than "Dakota's"?
I.B.A.#26543,
