0 Cases Full Of Oil
0 New users of Windows 10
Last Post: awesomeduror
0 Sprocket cover with chainsikle rearsets?
Last Post: Jason's Sporty
0 On starting a new thread
0 Loose oil pump feed fitting - 2019 Iron
0 Powerraythor conversion
0 RSD Rear-Sets for '04-'13 Sportsters
Last Post: kobra50
3 Shaky Dave Recovery
0 Deer hunting at stairman's.
Last Post: Bow only
0 Speed
0 gas cap
0 Buy A new battery
Last Post: denguy
5 What year is the most collectible Sportster.
Last Post: denguy
14 TC 88A Chat
0 sportster and a grand
gp9739 (75), danbango (72), andyman1958 (61), 55 Jr (58), Love2FixIt (50), keywan (48), C Dubya (45), CA71xlch (44)
Old 9th May 2013
DK Custom's Avatar
Sportster/Buell Model: 883L
Default DK Tank Lifts, What You Didn't Know, Need To Know, Want To Know, Updated Weekly!!!!!!
Here at DK Custom Products we offer tank lift kits to fit 1995 and up Sportys. The sizes are 1.5", 2", 2.5", 3" and 4". (The 4 inch tank lifts will only fit 2004 and up sportsters)
All of our Tank lifts are made from American Cold Rolled Steel and completed with a Durable Black Powdercoat Finish. All hardware needed is Included and is stainless steel. As with all of our parts, these come with easy to read step-by-step instructions.
Natalie
Click HERE - Ride Report Cabot Trail, Newfoundland Island & More
www.DKCustom.com
Phone: 662-252-8828
Text: 662-420-4891
DK Custom YouTube Videos
Lots of Photo's at Pinterest
Old 9th May 2013
joseph563 joseph563 is offline
joseph563 has a spectacular aura aboutjoseph563 has a spectacular aura aboutjoseph563 has a spectacular aura aboutjoseph563 has a spectacular aura aboutjoseph563 has a spectacular aura aboutjoseph563 has a spectacular aura aboutjoseph563 has a spectacular aura aboutjoseph563 has a spectacular aura aboutjoseph563 has a spectacular aura aboutjoseph563 has a spectacular aura aboutjoseph563 has a spectacular aura about
Looking for more pics of the various size tank lifts on the 4.5 gallon tank. Not sure how it will look with the bigger proportion style tank.
Old 10th May 2013
DK Custom's Avatar
There are pics in this youtube video of 4.5 gallon tanks with lifts
Natalie
Old 10th May 2013
JackAttack's Avatar
JackAttack JackAttack is offline
JackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant future
Hi Natalie,
I was wondering if you guys had any numbers for what your tank lifts do for useable fuel capacity. I have an 06 Custom with 4.5g tank and have been considering this mod for awhile but have always been hesitant because I don't want to lose riding miles.
Old 11th May 2013
DK Custom's Avatar
Depending on the size of your tank. It could possibly reduce your usable capacity by ⅛ to ⅓ of a gallon
However, in the real world, most people do NOT run their tanks until they are dry. Since that is the case there is no practical difference in useable capacity 99% of the time.
With a tank lift your fuel light may come on a bit sooner, but the fuel light acts as a type of “electronic reserve”. Generally there is still a gallon or more of fuel left in the tank when the fuel light comes on.
There are four different fuel gauges on Harleys. Not every model has all of them.
1. Digital Gauge
2. Analog or mechanical Gauge
3. MTE (miles to empty) read out
4. Fuel light.
The digital and mechanical gauges are notoriously inaccurate. While you can get to know how yours works with time, most use the trip meter to let them know when they are getting near needing to fill up.
In our experience, the MTE (aka Fuel Range) gives a fairly accurate reading. Remember, when it gets down to 10 miles, you still will have approximately 1 gallon of fuel left.
As mentioned above, the Fuel light is a type of “electronic reserve” when it comes on you will still have around a gallon of fuel left in the tank (if it is operating correctly). The way to know for sure is to pull into a gas station as soon as the light comes on. Fill up your tank. If you have a 3.3 gallon tank and you were able to put 2.3 gallons in, then you know that your light comes on with 1 gallon left. Do this a few times to get a feel for it.
One factor that affects all the gauges is going up or down a hill, or around a long left hand turn. You can watch your gauges go down even though you have plenty of gas. This is because the fuel pick-up in your tank is on the back left side of the tank. As the level of the gas in the tank is shifted on a hill or in a long sweeper, the gauges will give a false reading until you are level again.
Important Note: In a long left turn, or a steep hill, the fuel light can come on, even if you have a couple of gallons left. When you level out, it will not go off. Once the fuel light comes on, it will not reset until the ignition is turned off.
Now, down to what tank lifts do to the usable mileage. A tank lift could cause your fuel light to come on a little sooner than it did without one, and it could show you have less fuel than what you actually do. This is due to where the fuel pickup is located at on your tank. It is already in a sort of odd place, and leaves fuel at the rear of the tank that does not reach the fuel pickup. When you create a higher angle on the tank with a tank lift, it can leave more gas that will not reach the fuel pickup.
The fact of the matter is, for most, this possible loss won’t even be noticeable. This is because the only way you will notice that small of a loss of usable fuel, is if you drain your tank dry before you fill up each time.
Natalie
Old 11th May 2013
JackAttack's Avatar
The 1/8 to 1/3 of a gallon would have sufficed
I appreciate the response and extra info though, a little knowledge never hurt anybody.
Thanks for the response.
Old 13th May 2013
DK Custom's Avatar
Not a problem, Im going to be updating this thread with info, so I wanted to just go ahead and get the Information out there
Old 21st May 2013
DK Custom's Avatar
Tank lifts are an easy, inexpensive way to change the look of your ride. You can go anywhere from an 1.5" to 3" lift as long as you check for clearance to make sure it will work for you. Here is a pic of a tank lift on a Sporty:
Natalie
Old 29th May 2013
DK Custom's Avatar
Looks good!!!!
Natalie
Old 5th June 2013
DK Custom's Avatar
2in tank lift, 2in handlebar risers, coil and ignition relo, outlaw 587 air cleaner system, license plate relo. Thanks for the awesome parts!!!
Natalie
