Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Intake and Exhaust > Paying Taxes
Paying Taxes Got questions, tips or advice???
0 .551 Cams in an EFI 1200
0 1993 XLH883 Ignition switch Wiring
0 Multiple timing marks?
0 Handlebars
0 Riding in the rain
Last Post: seajay
0 Removing countershaft from access cover
Last Post: Russ
0 Anti reversion “muffler”
Last Post: JaKaL
Last Post: a-sad-anorak
0 question about new trans door
0 Where were the IronHead sportsters Made.
0 BMW reverse trike build
vlmuke, wazza (48), Grizzwold (44), roaldtm (39), redtacoma31 (34)
Old 14th August 2006
The actual air filter housing is a very restrictive piece along with the filter. Just changing the filter does not really make a big difference in performance.
pokeskickazzzz's Avatar
pokeskickazzzz pokeskickazzzz is offline
Sportster/Buell Model: 883 Low
pokeskickazzzz has disabled reputation
okay fine I'll spend more money... thanks for the help
Hey Dan can you help me to know exactly what all I need to order from there... I see where I can get the centered air cleaner but then it says I also need to get a separate bracket and there are other options like a breather kit etc...
If I get the centered air cleaner $209.95 and the black carburetor support bracket $10.65 will that be all that I really need?
geez air cleaner kits are expensive... the screaming eagle was $110.... but I've also heard they have a lot of problems
thanks
cory
sprtrjl sprtrjl is offline
Other Motorcycle Model: Heritage Softail Classic
sprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nice
The high performance filters have a different backing plate that allows air to come in all the way around the filter. If you do not change that part you may as well stay stock.
Did H.D. stop making the Screamin' Eagle air filter kits?
pfalvey pfalvey is offline
pfalvey has disabled reputation
How does the kuryakyn hypercharger compare to a/c's like the ness and hurricane?
Don Burton's Avatar
Originally Posted by pokeskickazzzz
Why not just replace the stock air filter with a K&N?.... yes i know newby
I think that Kentucky has put a stock replacement K&N in his modified stock airbox on his 1200. He drilled several holes in the backing plate to give it more air. I don't know how well it works but you might ask him. I would think that the Hurricane would work some better as it looks like the best a/c setup that I have seen but I don't know how much better it needs to flow on a stock 883 which will require quite a bit less air than a 1200. The replacement K&N stock replacement filter with a modified stock backing plate may be enough for an 883 and can be found for less than $50 including shipping. That being said, the Hurricane Flow sure seems like a fine product for maximum air flow and one hears nothing but good about it if you want the best that there is.
Shamdog's Avatar
Shamdog Shamdog is offline
Sportster/Buell Model #2: Dyna Low Rider
Sportster/Buell Year #2: 2004
Shamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished road
Hell, why not wait for the new ROUND Hurricane Flow?
Should be out any day now...Right Dan?
'00 1200 VC (Very Custom)
Daytona Ignition / SE Round AC / HSR 42 / NRHS Stage 2 XB Heads / Hurricane 10.5:1 pistons / SE .536 Cams / RB LSR 2-1 / Ghost Flames / Bling and...well, you get the picture
I have had the Screamin' Eagle on mine since about '98 never had any problem other the oil soak we've talked about elsewhere.
and you will have that with any of them including stock unless you correct the crank vents
cor cor is offline
cor has disabled reputation
Ya wow why so much money for an a/c?
Pipes made out of chrome aren't even double what an AC costs.
I was thinking v&h short shot staggereds + hurricane + some jet kit....but this would be about
$260 + $210 + ???? = > $600
