Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Era Specific and Model Specific > XR Sportster Motorcycle Talk - XR750, XR1000, XR1200
XR Sportster Motorcycle Talk - XR750, XR1000, XR1200 For XR Sportsters: XR750, XR1000, XR1200
Last Post: Baby883
Last Post: dodgetrucken
Last Post: Andy56
0 Zippers 1250 kit
Last Post: seajay
0 100 vs 110 front tire
0 mainshaft rollers size
0 MS rollers way too tight
Last Post: Rolli
Last Post: PappaBravo
0 Newbie
Last Post: BitterOldMan
0 KBS tank sealer
Last Post: jcro61
0 OEM Headlight Bucket?
Last Post: Mission1
0 Tools
0 my sunday driver...
0 -65A mufflers
0 my daily driver
Last Post: webman94
0 carbs?
0 Better Brakes
0 just for my head
Last Post: Iron Chuck
0 2020 End of Year Report
0 81 parts
Last Post: kobra50
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: exexpat93
Old 23rd September 2014
KRTTXRTT KRTTXRTT is offline
Sportster/Buell Model: XR-1000
Sportster/Buell Year: 1984
KRTTXRTT has disabled reputation
Default xr1000 Exhaust Spigot - Source?
Does anybody have a source for the aluminum exhaust spigot that is used to attach the head pipe to the exhaust port? I have a pair that are trashed from many sessions of over tightening and need to get a pair of these.. They are the aluminum pipe that is a press fit into the exhaust port. Not sure if XR-750's used these?
Thanks in advance
Old 21st October 2014
Streetpro's Avatar
Streetpro Streetpro is offline
Sportster/Buell Model: XR-750
Sportster/Buell Model #2: Sportster 89 ci.
Sportster/Buell Year #2: 1991
Streetpro is an unknown quantity at this point
Sorry, can't really help. No known source.
But wanted to inform you that this is a clear difference between xr750 and xr1000 heads.
Old 30th November 2014
RGT's Avatar
RGT RGT is offline
Sportster/Buell Model: XR 1000
Sportster/Buell Year: 1983
Other Motorcycle Model: Enfield
RGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the rough
http://www.hi-speedmotorcycles.com/w...CR%20Parts.pdf
I have seen them on ebay before too...
Old 3rd December 2014
XRCR XRCR is offline
Sportster/Buell Model: XR750 last year
Sportster/Buell Model #2: XR750
Sportster/Buell Year #2: 1977
Other Motorcycle Model: 80" ironhead
Other Motorcycle Year: 1974
XRCR is an unknown quantity at this point
Have a friend make two on a lathe. It is a simple job an apprentice machinist could do.
Old 9th January 2016
2cam 2cam is offline
Sportster/Buell Year: 1968
2cam will become famous soon enough2cam will become famous soon enough2cam will become famous soon enough2cam will become famous soon enough2cam will become famous soon enough2cam will become famous soon enough
Default Spigot
I have removed mine today. Bad state ...
dimension them out, might be lucky and a piece of aluminum conduit will fit or can be made to fit. the two inch conduit will fit nicely for a iron 1000, diff from yours. I plan on making some pipes for my ch if and when I ever get to it as after-market pipes are crap, had a new set rust on the shelf.
Old 10th January 2016
kiwiroadking kiwiroadking is offline
Sportster/Buell Model: xr1000
kiwiroadking will become famous soon enoughkiwiroadking will become famous soon enoughkiwiroadking will become famous soon enoughkiwiroadking will become famous soon enoughkiwiroadking will become famous soon enoughkiwiroadking will become famous soon enoughkiwiroadking will become famous soon enough
hi got sick of mine being a sloppy fit in the head so i got a guy to make and weld a pair in the head problem solved cheers
Old 19th March 2016
Default Spigot
I just changed mine. Easy job.
http://harley8valves.wordpress.com, http://www.facebook.com/twocam
Old 22nd March 2016
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
If you can supply EXACT measurements I could try to make some
Old 12th April 2016
Outside is 44,8 millimeters
Inside hole 34 millimeters
Lengh 38 millimeters
