Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Product Reviews
Product Reviews Here is where you can write up your own review of bikes, parts, or accessories.
Please do not post problems in here unless replying to a review. Please post problems with specific parts or accessories in their respective forum topics.
Last Post: dodgetrucken
Last Post: Andy56
0 Zippers 1250 kit
Last Post: seajay
0 100 vs 110 front tire
0 mainshaft rollers size
0 MS rollers way too tight
Last Post: Rolli
Last Post: PappaBravo
0 Newbie
Last Post: BitterOldMan
0 KBS tank sealer
Last Post: jcro61
0 OEM Headlight Bucket?
Last Post: Mission1
0 Tools
Last Post: 84rzv500r
0 my sunday driver...
0 -65A mufflers
0 my daily driver
Last Post: webman94
0 Now running 3.40 factory gearing
0 carbs?
0 Better Brakes
0 just for my head
Last Post: Iron Chuck
0 2020 End of Year Report
0 81 parts
Last Post: kobra50
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: exexpat93
0 Grateful Dead Timing Cover Source?
Closed Thread
  #71
Old 10th July 2010
Fat Tony's Avatar
Fat Tony Fat Tony is offline
Fat Tony has much to be proud ofFat Tony has much to be proud ofFat Tony has much to be proud ofFat Tony has much to be proud ofFat Tony has much to be proud ofFat Tony has much to be proud ofFat Tony has much to be proud ofFat Tony has much to be proud ofFat Tony has much to be proud ofFat Tony has much to be proud ofFat Tony has much to be proud of
Originally Posted by Epyx View Post
Is this this supposed to have a ham can covering it?
Yes it is supposed to be covered by the ham can which is why I totally disagree with Grind's complaints about the finish. Plus his acting like an ass earlier in the thread didn't help his case in my eyes either.
If so I would expect the ruff finish is not really relevent.
Exactly.
Also if the ham can is meant to cover over it, how is it different than the Screaming Eagle one from HD? Both use the same K&N filter, no? Just curious.
No, the SE kit uses a cheaper paper type element which is way crappier than a K&N filter. There is a replacement K&N filter available to replace the SE element. I believe the part # is HD0900 but i'm not 100% certain on that.
  #72
Old 10th July 2010
ElectricCityIron's Avatar
ElectricCityIron ElectricCityIron is offline
Sportster/Buell Model: XL 883N
Other Motorcycle Model: Sportster
Other Motorcycle Year: 1991
ElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to all
If you didnt like the way it looked then put the ham can on it, problem solved....
I know if i wasnt happy with something I bought i would have just called the guy before i did anything else, if it was THat big of a deal then you should have given it back before you did anything to the product...not smart dude...
F.T.W Molon Labe
  #73
Old 10th July 2010
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
Originally Posted by LuxBlue View Post
great system, beats the hell out of the Moco plastic crap.
And its only $210.00 not including the mounting brackets etc....
"We've done four already but now we're steady
And then they went: One, two, three, four"
“The larger brush provides coverage, but is incapable of detail.” - Sherwin Williams
“How can you have any pudding if you don’t eat your meat?”
  #74
Old 10th July 2010
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
I see no point in letting this go further. Thread is closed
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Closed Thread
