0 Saturday Sportster Season 2
Last Post: bagster guy
0 Fried Engine?
Last Post: Captain Johnny
0 Starting my project soon.
Last Post: ankered
0 Fiber Washer on Idler Gear
Last Post: DirtyHarry68
Last Post: Jtl2
0 It's been a great Ride!
Last Post: ed_in_az
Last Post: joe s
0 Bad Speedometer or Bad VSS?
Last Post: cookiemech
0 Need a rear fender
Last Post: SporterII
0 1999 S upgrades
Last Post: 84rzv500r
0 a man walks into a bar
0 My off-road build
0 Allegheny 2023
Old 29th September 2022
jazzman jazzman is offline
Sportster/Buell Model: 883
Other Motorcycle Model: 101 Scout,68guzzi,250duc
jazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud of
Maybe you need to add a gremlin bell?
Haha, the bike came with one!!
Sent from my CPH1725 using Tapatalk
denguy denguy is offline
Sportster/Buell Model: 1200
denguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond repute
Must have expired.
wedge's Avatar
wedge wedge is offline
That's why I never had one and never will. That thing attracts gremlins. See what you have done?
Old 30th September 2022
rejeanprimeau's Avatar
Sent from my CPH1725 using Tapatalk[/QUOTE]
Must be installed at the lowest point of the bike, no wonder it didn't work.
IT WILL come off again. like i said, interference fit, NOT a press fit. the guard is held by peen points. when it is assy at the factory, it is hydraulically pushed on and then a machine hydraulically presses the peen points TIGHT to the pulley.
you cannot weld steel to aluminum. i have seen some who attempt to repair to only have to pull it off again.
your dime but the potential is NOT one i would take!
that said, you can bring it to a machine shop and they can cut and attach a new aluminum guard but you will spend more than a new one. one point to make is that you NEED a GOOD tig welder as the two types of aluminum needs to be welded correctly or the joint will crack.
Crusty's Avatar
Crusty Crusty is offline
Sportster/Buell Year: 2016
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XL 1200 Cussed'em
Wouldn't it be simpler and cheaper to just replace the whole sprocket?
... interference fit, NOT a press fit...
interference fit and press fit.
Two terms that are interchangeable.
BKB's Avatar
BKB BKB is offline
jazzman said he was going to put some screws in it. That should keep it in place well enough. It's what I'd do, cause I'm too cheap to spend $, if I think I can fix it myself with what I've got already in the garage.
wedge's Avatar
I agree. If there is room for screws to be drilled and taped into place then that's a perfect cure. Flat heads countersunk may help with any clearance issues? I would use 6 or more,
spaced evenly.
Sportster/Buell Year #2: '03
in the motorcycle world,buster's liable to have an industrial scenario.i spend 5 day's a week in the industrial world,so i'm expecting to hear.
