0 Getting ready to try firing it up after a year long rebuid
Last Post: nychopper
Last Post: stikflote
0 Arun Floods
0 Clunking into 1st after Clutch is engaged and shifter is pressed
0 my recent ebay purchase
14 Mid controls??
0 Intake manifold
0 Black Bike Bible
Last Post: 83XLX
0 Roadster CX Cafe Build
Last Post: Otter
0 HAMMERPerf 90" In the Works
Last Post: Carl74
0 CV40 spacing
Last Post: Carl74
0 Lucas fuel stabiliser
0 900 heads contd..
0 my only real beef with my 03 883
Last Post: robbie202
3 Wtb, Wts, Wtt, Wtg (Evos)
0 Harley-Davidson Sales Slump: What Next?
Last Post: brixtonanima
0 new to me 883
0 Dyno AFR and plugs on my 1275 04 Sporty
Last Post: Hellbent_4
0 Too HOT to ride?
0 Tank Paint Ideas
Last Post: MotorPete
0 Trans corner fix
cbsportster (69), sjeccles (52), 2011_Nightster (52), reeb (49), Maff (49), jl_rotary (42), UMLsilva (34)
1977, help!, leak, newbie, oil
Old 30th May 2017
Rocki's Avatar
Rocki Rocki is offline
Sportster/Buell Model: XL
Rocki is an unknown quantity at this point
Exclamation Oil Leakage, NEW to XLForum
FIRST: I'm new to these Forums, so trying to navigate through these threads has been difficult.
SECOND: I've acquired a 77 Sportster. It hadn't run since 1998. I've spent 2.5 years trying to make it go. I've done a few things on it (and I'm new to this mechanic stuffs, too), but with the help of a friend, it lives on. It's been a mess, one thing fixed another thing fails, but that seems to be what I've been reading, at least until it becomes a regular rider.
THIRD: My major issue currently is oil leaking. I took it for a short ride with my bro-in-law, and the sucker is smoking like crazy from all of the oil burning off of the pipes, fins, and anywhere else it's hot enough.
I have already readjusted the pushrods, and replaced the cork seals, and I checked them again today to make sure adjustments were good. I probably could replace the cork again, but I just wanted to check adjustments. Everything seemed kosher. Until I road it tonight. Still leaks significantly.
When I got it back home after another short ride tonight, I noticed that i have oil leaking from the cable going from the right side of the case to the speedometer. WHA!?
Any advice is good advice at the moment. Thanks for this outlet!
Old 30th May 2017
Rocki's Avatar
Old 31st May 2017
Mosey Mosey is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: FX
Other Motorcycle Year: 1976
Mosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond repute
First ya gotta locate the source of the leaks. A good cleaning and de-greasing is where ya start. A liberal coating of baby powder can be a good way to find leaks as can paper towels tucked into various spots while you run/ride yer machine.
Once you find the source then the gurus can tell ya what the appropriate fix should be.
Old 31st May 2017
BTW, I can't see yer pics and, most importantly, post ALL your Ironhead questions in the Ironhead section of the forum. Ironheaders almost never leave that area.
