0 Valve to piston contact
0 Horn and starter button stop working
Last Post: Roane
2 Humble pie
Last Post: Racepres
0 Falling out of 1st
0 Ironhead questions
Last Post: The Doctor71
0 codes
Last Post: dwint
Last Post: Hopalong48
0 Hello
0 Child Car Seats
Last Post: andy_t
0 Size Matters
Last Post: motorend
Last Post: Akdawg
0 2018 Custom seat fitment
Last Post: motorend
0 is a buell a harley
Last Post: Phelan
0 2002 lightning rocker box
Last Post: spamer80
0 Iron 883 headlight grill keeps spinning
0 grinding noise.
0 Exhaust ground clearance
Last Post: Truckedup
6 Violin Bows
Last Post: Pender1
0 New WTF Happened
0 Electronic Ignition - getting to maximum timing advance 45° BTDC ?
Last Post: chevelle
0 Yet another issue with this build
Last Post: seajay
Nytstr (71), mccudden2 (54), willy (50), NHMike, xl1200boost (39)
  #101
Old 19 Hours Ago
Originally Posted by Chicken-hawk View Post
thanks. So we've narrowed it down a 72 frame with a 73 motor. Did they stamp the 58 casting on 72 frame necks?
no.it appears your 1972 long frame neck casting was swapped out for a-58 short frame neck casting.a front end collision is a likely reason for this.your bike has a later model dual disc front end on it iirc?
Old 15 Hours Ago
The mag has a key lock on it.
Old 12 Hours Ago
Chicken-hawk Chicken-hawk is online now
Sportster/Buell Year: 73
Chicken-hawk has a spectacular aura aboutChicken-hawk has a spectacular aura aboutChicken-hawk has a spectacular aura aboutChicken-hawk has a spectacular aura aboutChicken-hawk has a spectacular aura aboutChicken-hawk has a spectacular aura aboutChicken-hawk has a spectacular aura aboutChicken-hawk has a spectacular aura about
Yes it does but the ignition key dosent fit. Why?
Is that how you cut off the engine?
Old 12 Hours Ago
Yes you can shut it off with the key.
Not the same as the ignition key.
I think it is a file cabinet key.
Get the number off the lock cylinder.
Old 12 Hours Ago
Ok thanks for the help I have no experience with a mag setup. Right now I turn the ignition switch on to start it
But then have to push a button on the right switch pod to kill it. Is this typical?
Old 12 Hours Ago
yes Mag bikes had a kill switch on the bars.
Old 11 Hours Ago
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Iron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant future
Try to start it with the ign key off. That may just be the disconnect for the battery for the lighting circuit.
Old 16 Minutes Ago
The Doctor71 The Doctor71 is online now
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
The Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant future
Bruce, maybe this will help demystify the neck casting question. This pic is from my original '71 xlch long frame. I hope it is clear enough to show that neck casting # 47594-58 was being used in 1971 on long frames.
I don't have an original short frame in hand to do an A) vs B) comparison..... but I assume it's reasonable to conclude the factory was using neck casting # 47594-58 on both short & long frames back in the day.
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
The Doctor71, spacecoast, Chicken-hawk
