0 Arun Floods
0 Getting ready to try firing it up after a year long rebuid
Last Post: nychopper
Last Post: stikflote
0 my recent ebay purchase
14 Mid controls??
0 Intake manifold
0 Black Bike Bible
Last Post: 83XLX
0 Roadster CX Cafe Build
Last Post: Otter
Last Post: Carl74
0 CV40 spacing
Last Post: Carl74
0 Lucas fuel stabiliser
0 900 heads contd..
0 my only real beef with my 03 883
Last Post: robbie202
3 Wtb, Wts, Wtt, Wtg (Evos)
0 Harley-Davidson Sales Slump: What Next?
Last Post: brixtonanima
0 new to me 883
0 Dyno AFR and plugs on my 1275 04 Sporty
Last Post: Hellbent_4
0 Too HOT to ride?
0 Tank Paint Ideas
Last Post: MotorPete
0 Trans corner fix
cbsportster (69), sjeccles (52), 2011_Nightster (52), reeb (49), Maff (49), jl_rotary (42), UMLsilva (34)
gauge, light, oil, pressure
Old 1st June 2016
extra_bolts's Avatar
extra_bolts extra_bolts is offline
Other Motorcycle Model: Kawasaki KZ 750 LTD
Other Motorcycle Year: 1982
extra_bolts is on a distinguished roadextra_bolts is on a distinguished roadextra_bolts is on a distinguished roadextra_bolts is on a distinguished road
Default Oil pressure light
1974 Ironhead 1000. After doing some reading I have decided I'm not going to use an oil pressure gauge but just the light. I just want to confirm this, but if the light is off while the bike is running you have oil pressure & if the oil pressure light comes on then your in trouble. Correct?
Old 1st June 2016
trappnman's Avatar
trappnman trappnman is offline
Sportster/Buell Model: XLCH- old school chop
Sportster/Buell Year: 1973
Sportster/Buell Model #2: 1981 XL
Other Motorcycle Model: Norton HighRider
Other Motorcycle Year: 1971
trappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant future
the light comes on when pressure is low-
CHOPPERS MC S.E. MINN- Chopper for Life- "Old School" Steve Gappa on facebook
Old 1st June 2016
Flatheadkid Flatheadkid is offline
Sportster/Buell Model: Xlh
Other Motorcycle Model: 1950 WL, 1969 Flh
Flatheadkid is on a distinguished roadFlatheadkid is on a distinguished roadFlatheadkid is on a distinguished roadFlatheadkid is on a distinguished road
You're correct
Old 1st June 2016
keystone's Avatar
keystone keystone is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: yamaha dt-250 enduro
Other Motorcycle Year: 1975
keystone is a jewel in the roughkeystone is a jewel in the roughkeystone is a jewel in the roughkeystone is a jewel in the roughkeystone is a jewel in the roughkeystone is a jewel in the roughkeystone is a jewel in the roughkeystone is a jewel in the roughkeystone is a jewel in the roughkeystone is a jewel in the roughkeystone is a jewel in the rough
Default oil light
If you wanna see an angel,you gotta find out where she fell. (ozark mountain dare devils)
Old 2nd June 2016
smac74 smac74 is offline
Other Motorcycle Model: KX 250F, XR200
smac74 is a name known to allsmac74 is a name known to allsmac74 is a name known to allsmac74 is a name known to allsmac74 is a name known to allsmac74 is a name known to allsmac74 is a name known to allsmac74 is a name known to allsmac74 is a name known to allsmac74 is a name known to allsmac74 is a name known to all
Haven't got my ride on the road yet, but as I understand it from the forum here, the light may come on at low idle but should be off as you bring the revs up. If it stays on then, you're in trouble.
Old 2nd June 2016
Fridge's Avatar
Fridge Fridge is offline
Sportster/Buell Model: XLCH/H
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has disabled reputation
Well,,, mine is always off until I turn the ignition to on, then the light comes on, stays on until I start the engine,then the light goes completely out..... not dim, not on at low idle(which is not good for motor), only off.
Now, the generator light,,, it will dim and get bright with the RPM's of the engine.
It's especially noticeable an night time.
Old 2nd June 2016
Yellowstone Kelly's Avatar
Ironhead Rider
Sportster/Buell Year: 1982
Sportster/Buell Year #2: 1969
Other Motorcycle Model: FLSTC
Other Motorcycle Year: 1996
Yellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant future
+1 to everything Mr. Fridge says.
The only time my genny light flickers on is when it's reminding me I'm being a dumb a$$ by adjusting my idle too low.
The oil light should be off anytime the engine's running, in my experience.
