Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
0 900 heads contd..
Last Post: Magneto Sportster
0 XL1200R / Roadster Seat and Shocks
Last Post: OakBehringer
0 Black Bike Bible
Last Post: SCarty
Last Post: jak
0 The forum got talent
Last Post: r4fthrs
0 Stock vs. Modified
Last Post: paulc
Last Post: chevelle
0 For all you rookies out there.
Last Post: lostNdallas
Last Post: Dave L
0 Oil leak after assembly ?
Last Post: jordan1200
5 Other Bars instead of Buckhorns?
Last Post: chevelle
0 What jets do you use?
Last Post: David L.
0 ‘68 XLCH...transmission
Last Post: DirtyHarry68
0 Any K model guys interested in cam regrinding?
Last Post: T. Clark
Last Post: xElvis
0 Whats a bigger priority - FF or W/shield?
0 K&N or UNI Foam
10 Greetings from upstate NY
5 RF turn signal flashing way too fast...
Last Post: stray
0 Brake Squeek
0 The country store
0 79 Engine Rebuild
Last Post: Peteroo
0 Crashed my sporty today :(
Last Post: stray
0 Laconia Motorcycle Rally 2018
Last Post: tvon
breilly888 (66), txsporty (62), michtif (53), Rabs (45)
Old 11th May 2018
mattjs666's Avatar
mattjs666 mattjs666 is offline
Sportster/Buell Model: XL883C
mattjs666 is an unknown quantity at this point
Default Bars on C Riser?
I want bars that are a bit higher but also to keep the riser on the 04-06 riser that comes on the 'C' models.
I like the chumps/ mini apes but not sure about the look of them on that riser.
Anyone got pics of higher bars on the C riser?
Subscribing Biker
Toejam503 has much to be proud ofToejam503 has much to be proud ofToejam503 has much to be proud ofToejam503 has much to be proud ofToejam503 has much to be proud ofToejam503 has much to be proud ofToejam503 has much to be proud ofToejam503 has much to be proud ofToejam503 has much to be proud ofToejam503 has much to be proud ofToejam503 has much to be proud of
These are 8" Chumps
mattjs666's Avatar
Those look nice. Thanks!
Did you have to swap all of the cables out ?
Sent from my SM-G960U using Tapatalk
Folkie Folkie is online now
I think higher bars on the Custom riser look a bit odd. Bite the bullet and swap out the riser:
I didn't have to swap the riser; my Custom came like that from the factory.
Subscribing Biker
I didn't have to swap anything but I rerouted the wires under the tank and bent the soft brakeline straight. After a week of riding, I decided that it didn't look clean enough so I ordered a 4" wire extension kit (Novella) from Dennis Kirk and a 4" longer single Brakeline from them also. The throttle cables are routed behind the triple tree and the clutch cable was plenty long enough. P.S. I like that CUSTOM 5" riser, it has a definite COOL factor !
