0 question for our machinists
0 *DK Custom - Our Gift to You - Holiday Savings*
Last Post: Yakcm2
0 Fact or fiction?
0 You can't tour on that!!!
Last Post: RDHenley
Last Post: herostar
0 Black Friday/Cyber Monday Showoff Thread
Last Post: herostar
0 XLCH Plunger Seat Kit
Last Post: FatboyBill
0 hi all
Last Post: early iron
0 Swingarms
0 the roadster make more power ?
0 supply oil line seeping
0 Question on priming motor for kickstart
0 Interview of My Expieriences Riding in the Iron Butt Rally
0 Hydraulic Lift For XL
0 3.5" straight riser
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
Last Post: Nacs
Old 10th October 2019
Bmg17a1 Bmg17a1 is offline
Sportster/Buell Year: 65
Bmg17a1 is an unknown quantity at this point
Default '65 xlch mag question....
Does the helical drive gear have a specific location on the shaft relative to the point cam and rotor?
Installed a Hunt rotor that never had the gear on the rotor shaft and copied or approximated the placement of the pin hole from the old rotor and drilled it.
Given the wide latitude for adjusting the timing it seems that it would not matter.
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
I wouldn't think it would matter as it could be adjusted out, if it even needed to be.
Ok, now I'm revived
