Last Post: Bikeaholic
0 Swingarm bearings - boy I'm glad I looked at them
0 any fans of motogp ?
0 Stacking the Alto Carbonite clutch !
0 I luv my jack,hammer
Last Post: cazz1000
0 heads. what to do?
Last Post: ericfreeman
0 Finally Got the Kinks Out
0 The demise of American Brands
Last Post: 11B40
0 1972 XLH question
0 Whats your carry gun?
0 2.18 Gearing Ratio For 5 Spd 1200??
Last Post: Rangry64
3 Shaky Dave Recovery
Last Post: Knuckles
0 New to the Chopper Lyfe
Last Post: Bigshankhank
0 Rocker cover torx
0 Touring on a Hugger
Last Post: Racepres
0 The huge difference 4 degrees of Advance makes ...NOT
0 Back rest compatability
0 Round Air Cleaner Poll
Last Post: Clevspeed
0 Alarm Time Out?
Last Post: XL Ed
Last Post: burely
TenSixx (44), 1stGenRex (36)
no start, starter relay
Old 19th August 2014
Skylar's Avatar
Skylar Skylar is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: 1993 883
Skylar is an unknown quantity at this point
Default Full power, headlight, console, etc- no electric start. Starter relay clicks.
- and when I put my finger on it, I can feel a click inside of it, in conjunction with touching the start button at my controls. So, audible clicking and you can feel it, both at the starter relay.
1993 883. I cleaned the ignition connections at the breaker, the corrosion was slight but I did it anyways.
No change.
SO-
Bad relay? Bike sat for 20 years, I spent awhile going through it and have put 355 relatively trouble free miles on it up until now.
Thank you XLF. -S
xlron's Avatar
xlron xlron is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 1988
Sportster/Buell Model #2: 2001 xl
Sportster/Buell Year #2: 1980
Other Motorcycle Model: Honda cx500
Other Motorcycle Year: 82
xlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to all
Put a multimeter on the end of cable/post @ the starter to see if its the cable from the battery. You should get the same voltage there as your batt. If you do get the same volts there. Pull the small wire off (from starter button to relay to batt), ground your neg side of the meter, and stick the red (pos) on the spade connecter, press the starter button. If no juice there its probably the relay.
Sounds like it might be battery cables or a ground cable - You want to yank test those cables - don't be gentle.... If they don't move, then make sure you wrench tighten them to their connections... Be sure to check every ground cable... and the positive cable at the battery...
You might want to take a look at the checklists in this thread:
http://xlforum.net/forums/s....php?t=1792262
__o~~o__
IXL2Relax
>>>> Ride Reports Are Here <<<<
Skylar's Avatar
__o~~o__
IXL2Relax
Good idea. I figured since there was that kind of activity within the relay itself that may be a red flag for replacement, but the checklist is prudent. Positive cable at the battery is on tight as I've undone the battery many times today troubleshooting. Thank you for the info and I'll keep hunting based off this.
Skylar's Avatar
Also I forgot to mention it got rained on all day earlier in the week and then sat out in the rain several days later, so I was thinking the relay might've gotten waterlogged.
sportsterdoc's Avatar
Check BOTH ends of BOTH battery cables and do some voltage checks
http://xlforum.net/forums/s....php?t=1784651
Old 29th August 2014
Skylar's Avatar
Well for future riders with these symptoms I've come back to update- it was absolutely the starter relay. Put a new one in and it fired right up. 8 dollar part I should've just replaced from the get go.
I will likely try to relocate this relay as well due to the poor location from the MoCo. No idea whether the rainy month we've had figured into the failure of the relay unit itself, I can only tell ya it's the silver bullet to my startup woes.
Thanks for all the excellent troubleshooting advice XLF.
