0 Sportster tachometer wiring question
Last Post: Doc308
0 Rumble strips
0 Help with my clutch please
Last Post: HotRod917
0 03 xlh 88"
Last Post: splineman
0 '71 XLCH starting issues, any ideas?
0 Where to buy starter brushs 69xlh
Last Post: Chillmech
0 Clunk when clutch released quickly
0 Why do sportsters look small?
Last Post: Martysf
3 Shaky Dave Recovery
Last Post: Martysf
0 Front brake shorting?
Last Post: Hughieboy
0 Carl!
0 Motorcycle oils or not ?
0 S&S pushrod adjustment
0 07 heads on 04 rubbermount
Last Post: DéDé
0 INNOVV K2 Motorcycle DVR
Last Post: Ocgreenmachine
Last Post: farmall
0 modifying to metal oil tank.
0 THE Trainspotting Thread
0 If I Could Build My Perfect Roadster...
Last Post: Toro81
Papatony, chedd (73), Nevar (68), nrbase (66), Smokin-Smitty (61), kbfarkas (59), Irondreads (49), Tim97509 (48), CCM0021 (47), wandrur, bikerusn5 (35)
  #141
Old 5th December 2015
runingmouse's Avatar
runingmouse runingmouse is offline
Sportster/Buell Model: xlx
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Sprint ss
Other Motorcycle Year: 1967
runingmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura about
Brushes must be on the wrong terminal. Or orientated incorrectly then.
Changing + and - reverse rotation. Good luck with it.
Old 2nd April 2016
wymanv's Avatar
wymanv wymanv is offline
wymanv will become famous soon enoughwymanv will become famous soon enoughwymanv will become famous soon enoughwymanv will become famous soon enoughwymanv will become famous soon enoughwymanv will become famous soon enough
Cool
Originally Posted by smokey 2 View Post
Mick, there is a ton of great info in here, thank you and all contributors.
One question for now. I am running the bench test on a generator I have on the shelf,
and it runs counter-clockwise, backwards from what the test says. What the heck
does this mean?
Had this issue a few months ago after a generator rebuild and for anyone else dealing with this, yes the wires are oriented wrong...inside. Pulled mine apart again and switched them. Squared the generator right away.
Ken
Arrogantly twisting the sterile canvas snoot of a fully charged icing anointment utensil...
Old 3rd April 2016
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
All 2 brush generators have the A lead connected to a field winding and a brush. "F" terminal only has a field wire
the other brush lead goes to ground.
http://www.ruiter.ca/mc/info/PDFs/1R-118.pdf
Old 5th April 2016
khav's Avatar
khav khav is offline
Sportster/Buell Model: XLH Bobber
Sportster/Buell Year: 1979
Other Motorcycle Model: Honda ST1300
khav is just really nicekhav is just really nicekhav is just really nicekhav is just really nicekhav is just really nicekhav is just really nicekhav is just really nicekhav is just really nicekhav is just really nicekhav is just really nicekhav is just really nice
Glad this got a bump...facing these issues myself with the recent purchase of a '78 XLH Anniversary Edition. Working through what seem the typical charging system issues and this guide is proving to be most useful.
Old 5th April 2016
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
Please start a new thread and post up a pic of your '78 AE. There are a few of us on here with one of those.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Stick_Man's Avatar
Stick_Man Stick_Man is offline
Sportster/Buell Model: 1981 IronHead
Other Motorcycle Model: 1975 Aermacchi/H-D SX 175
Stick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura about
does anyone know the field coil test? My Haynes manual has like no tests in it.
I am totally stumped on why my battery does not charge. It looks like I cooked an armature ( i took it off and brought it to an auto electric place and they said "this is burnt.")
I have tried: putting in a new wire and pole for A terminal; switching regulators; putting in a NOS HD armature; polarizing gen and nothing works.
A burned armature is usually caused by a runaway generator (unregulated output).
Usually caused by something shorting the F terminal to ground.
"Flashing" the F terminal will burn the regulator contacts together and cause this.
If you have a working generator light there is no need to polarize, the generator polarizes on every start.
Running the bike on a dead battery can smoke the armature.
Running high wattage Halogen lights can overload a generator.
Field coil failures are not common.
Check for continuity across the coil and short to ground.
If you are testing installed coils the A terminal brush must be lifted to open the path to ground through the armature.
