Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Riding Tips & Safety Advice
Riding Tips & Safety Advice Got a question about your riding technique or safety issues?
0 1960 XLCH in the UK
Last Post: lynnx
Last Post: Guidorey
0 E85 Fuel
Last Post: hondo
Last Post: fafcpa
0 Branch Mikuni Air cleaner question
Last Post: Doc308
Last Post: fafcpa
Last Post: Doc308
0 15 min rides
Last Post: 72 Ironhead XLH
0 Replacement Clutch/Rotor Magnets
0 97 Sportster Kickstand Problem
Last Post: Dirt Road Cowboy
0 back to factory clutch
0 removing clear coat on fork lowers
0 HELP! Extra part found
Last Post: syrnetworkin
0 48 O2 sensor?
Last Post: jvandivere
0 Starting issues (No Spark)
Last Post: jimstogs
0 The forum got talent
0 Battery melt down
0 Common ironhead problems
0 Hello from Tampa, Fl
0 Resto-Repair 84 ironhead
Last Post: Yochstein
0 Getting Hammered
Last Post: Bryan1976
0 Greetings from Denmark
0 Howdy ya'll
Old 9th January 2006
DM-SC's Avatar
DM-SC DM-SC is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Heritage Classic
DM-SC is an unknown quantity at this point
Good read!
Some minds are like concrete..thoroughly mixed up and permanently set!
2004 Heritage Classic - Ness Big Sucker, V&H Longshots, PCIIIUSB
Former Sporty Pilot...Now riding a "Road Sofa"
kjbsporty's Avatar
kjbsporty kjbsporty is offline
Sportster/Buell Year: 02
kjbsporty is an unknown quantity at this point
I have read this before. It is some really good info. Try to practice it when I am riding. I have a friend who's pace is a little slower then mine in corners. When I lead he catches up on straights and when he leads I back off. It works fine.
Kevin
If you would rather be riding your Harley, why aren't you?
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
I agree with most of that, but I think it's a little misleading to define the apex as the tightest part of the corner. The apex is the point in the corner where you're closest to the inside. Whether or not that's the tightest part of the turn depends on the line you chose. In the technique he's promoting (slow in, fast out, with a late apex), I would think the tightest part of the turn would be the turn-in point, no?
669Sprink's Avatar
669Sprink 669Sprink is offline
Sportster/Buell Model #2: XLX 1000 "BLACK BETTY"
Sportster/Buell Year #2: 1984
Other Motorcycle Model: XL883
669Sprink has a spectacular aura about669Sprink has a spectacular aura about669Sprink has a spectacular aura about669Sprink has a spectacular aura about669Sprink has a spectacular aura about669Sprink has a spectacular aura about669Sprink has a spectacular aura about669Sprink has a spectacular aura about669Sprink has a spectacular aura about669Sprink has a spectacular aura about
Great Post, Thanks Stevo!
KSFFKS S.Y.L.K.S
Desertfox's Avatar
Desertfox Desertfox is offline
Sportster/Buell Model: 2001 883 Custom
Desertfox has disabled reputation
Tatally agree, it depends on the line you take. The danger of an unfamiliar diminishing radius turn is that when you go into it, it is easy to misjudge and while the speed may not be an issue going into it, as the radius gradually (sometimes suddenly) decreases you find yourself doing some serious braking while trying to compensate steering. I find freeway off ramps and interchange ramps here in Houston notorious for their diminishing radius curves. These kinds of curves are virtually impossible to see comming if you are not familiar with the road.
Flamin883's Avatar
Flamin883 Flamin883 is offline
Sportster/Buell Year: 94
Sportster/Buell Model #2: 1200C
Sportster/Buell Year #2: 03
Flamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura about
I have to agree with both of you. I think he is talking about the apex of the road, and your talking about the apex of your path of travel. 2 slightly curves
Or maybe i'm just in left field again
Kyle
94 Flamin 883
9.5-1 1200 flat tops under Flow Tech worked 883 heads
SE ac, SE bolt in cams
CS tapered cut exhaust
kiltbill's Avatar
kiltbill kiltbill is offline
Sportster/Buell Year: 09
Other Motorcycle Model: Electra Glide... GONE NOW
Other Motorcycle Year: 07
kiltbill has much to be proud ofkiltbill has much to be proud ofkiltbill has much to be proud ofkiltbill has much to be proud ofkiltbill has much to be proud ofkiltbill has much to be proud ofkiltbill has much to be proud ofkiltbill has much to be proud ofkiltbill has much to be proud ofkiltbill has much to be proud ofkiltbill has much to be proud of
Default Cheer's
Thanks Stevo, timely reminder...
Sportster Girl's Avatar
Sportster Girl Sportster Girl is offline
Sportster Girl has disabled reputation
Thanks Stevo!
I really appreciate any article that can help with my riding skills....keep 'em coming!
aswracing's Avatar
Here's what I'm getting at.
The yellow line is what he's talking about. This is really the safest way to go through a corner. You give up entry speed to gain exit speed. The apex (place where you're closest to the inside of the turn) is very late. But the tightest part of the turn is not the apex, it's between the turn-in and the apex. By the time you're at the apex, you're straightening it out pretty good and getting on the throttle.
What you never want to do is in the red, apex it early. You run out of room at the exit of the turn very quickly, and are forced to make a sharp turn out there. You've gained a lot of entry speed but lost all your exit speed.
The fastest way through the turn is the green. But I agree with the author, you're not racing. Use the yellow line. It's plenty fun and much safer.
DM-SC's Avatar
I think the green line is the safest based on the fact that you are leaning less...though you are leaning longer.
Of course...the rider's speed is what makes it "safe" or "fast". What I'd call fast in that corner, a braver, more experienced rider might call really slow...
