Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Custom Finishing
0 newbie
Last Post: mrsunshine
Last Post: ronccc
0 New member
0 Royal Enfield speeding ahead in Asia
0 my local dealership closed today
0 Knocking in Front Cylinder Until Warm (Before & After Rebuild)
0 Fork oil q
Last Post: Doc308
0 Fng
Last Post: XL1275
0 73 Electric Start won’t run after firing
Last Post: Erikdowney18
0 New oil tank
0 Bean in a can (rattling when accelerating)
Last Post: rickxx
0 Regulator/rectifier question
Last Post: LenC
5 Is factory Stage 1 worthy?
0 Removing transmission 1973 XLH
0 Any Teamsters?
0 07 Ign Acc position.
0 Real Dogleg Levers - 1977 XLCR
Last Post: spiritof67
0 Hi everyone
Last Post: catpepper
0 2002 1200 XLC screamin Eagle air filter
Last Post: lespaul6
5 Blue V By Name?
Last Post: Clevspeed
Johnc (74), x750rider (67), bart53 (67), bad rad (66), halfdrive (55), jag1 (48), Zuhaib (36)
Old 2nd August 2006
Mortarmanmike120 Mortarmanmike120 is offline
Sportster/Buell Model: XB9 Lightening
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1981
Mortarmanmike120 has disabled reputation
Default What about the new frame/tank?
Hi guys,
I've got a 2003 XB9S and I LOVE my bike. I'd be perfectly content driving her stock for the rest of my life. But hypothetically speaking, if one was to want to change the matte silver color of the frame/tank, what will work. I don't want to remove the frame - way too much effort and unease (fear) involved.
What can safely be done with the tank on the bike that will give good results?
It's cast aluminum - polish? I'm not sure if I'd like that unless it came out perfectly. Any issues?
Powder coat? can you do that on a gas tank? Is there an issue with the electrical current involved?
Regular paint? I'm not sure how to prep the aluminum with it on the bike.
Does anyone know if there's any kind of protective topcoat already on the frame or is it raw aluminum?
Thanks for your time,
Mike.
Believe the commercials - BUELL OWNS THE CORNERS.
Old 3rd August 2006
grizz420's Avatar
grizz420 grizz420 is offline
Sportster/Buell Model: 05 1200R
Other Motorcycle Model: V star classic wife's
grizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the rough
I'm guessing they put some sort of clear coat on it like on the lower forks so it doesn't oxidize but I'm just guessing
05 1200R Forcewinder XR air filter, Mikuni HSR 42,Super Trapp 2-1 pipe,TC88a ign., head light visor, chin spoiler, sport front fender, solo seat off 883, 12 and 1/2 inch dual rate Works shocks , dual rate Works fork springs
Old 28th October 2006
bsporty's Avatar
bsporty bsporty is offline
Sportster/Buell Model: 1200 xlc-miss it
Sportster/Buell Year: 00
Other Motorcycle Model: Honda CB750F
Other Motorcycle Year: 78
bsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant future
I am not too sure what an 03 looks like but I can tell you it is possiable to make clear coat with a medium or satin finish.Got any pics of your bike?
Brandi
2000 Sportster xlc drag/cafe
It is better for others to think you are a fool, than to open your mouth and remove all doubt.
What does cheese say when it gets its picture taken?
Old 8th February 2007
xl1200r's Avatar
xl1200r xl1200r is offline
Sportster/Buell Model: Buell 1125CR
Sportster/Buell Year #2: 1964
Other Motorcycle Model: Kawasaki Ninja 250
xl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura about
There's just regualr sating-finsh paint on the frame and swingarm.
You can paint it any way you want - paint it just like steel for the most part as they both oxidize (steel does this faster in fact). You can also powdercoat, but both of these you would need to remove the frame to get good results. If you powdercoat, you HAVE to remove the frame as it needs to put into an oven.
About the only think you can do is polish it without removing it. I've seen a number done like this with good results so long as you like the look. I don't care for it.
